Size Comparision?
Old Nov 26, 2007 | 03:25 AM
20tCDude05's Avatar
Default Size Comparision?
I am looking to buy a GT3076R turbo by Garrett. I currently have an ITS T3/T04E right now at 9.5 psi and I am not happy at all with it. So, how much HP more would I get with the GT3076R? Is that the best turbo for this motor? It seems like it after talking to a few people.
Old Nov 26, 2007 | 05:43 PM
Simplyscion's Avatar
Team No Limitz
Default Re: Size Comparision?
what exactly arent you happy about with the t3/t4?
Old Nov 26, 2007 | 05:48 PM
Guru's Avatar
GT3076 is listed on Garret's website so that you can compare wheels sizes and flow charts. In my experience it is an excellent turbo for middle of the road power. It the smallest of the ball bearing turbos I would ever use on this motor due to the long stroke and large displacement. In my experience you can get about 500 WHP Max out of that turbo on race fuel. Spool up is quick and works very efficiently. It is available with the stainless steel housing as well which adds quite a bit of flow and efficiency to the turbo. I would highly recommend that option.
Old Nov 26, 2007 | 07:29 PM
20tCDude05's Avatar
Paul said that a T61 may be a better option because I want to get to 325WHP and 325WTQ at 10 PSI easy.
Old Nov 26, 2007 | 09:16 PM
Guru's Avatar
I don't see why you could not get those numbers on the GT3076.
Old Nov 26, 2007 | 09:54 PM
TurboToyotas's Avatar
What are you making now?
What spec is your T3/T04E?
Yes the GT3076R is a good turbo.....especially when trying to achieve a certain goal
But if all you want is 325whp and matching torque, you dont need to go and spend over a grand on a new turbo. You can if you want too, but there are easier and more economical ways to do so.
Again what are you currently making and we can go from there.
Regards-
Todd
Old Nov 26, 2007 | 10:52 PM
Mightygnu's Avatar
With my current setup t3/t4 54 trim, .63 AR I am right there, why do you need a larger turbo. Use your money elsewhere, especially looking at your goals in the long run.
Old Nov 26, 2007 | 10:56 PM
20tCDude05's Avatar
259WHP and 287WTQ with a T3/T04E .63 A/R and 60 trim. That answer your question?
Old Nov 26, 2007 | 11:04 PM
at 9.5psi right?
What altitude are you at? Or the altitude of where you had your car tuned?
So you want to gain another 65 whp at almost the same psi????
Just out of curiosity, why don't you want to run more boost? Wether its a new turbo or the same one.... just being nosy
Plus it all helps in pointing you in the right direction.
Regards-
Todd
Old Nov 26, 2007 | 11:18 PM
paul_dezod's Avatar
Scionetics
KAD
at 9.5psi right?
Regards-
Todd
He is in Colorado Springs, CO, which is 6,320 FEET ABOVE sea level
Old Nov 26, 2007 | 11:22 PM
SO are those numbers corrected or uncorrected? I can assume but I don't want to be wrong.
Regards-
Todd
Old Nov 26, 2007 | 11:30 PM
20tCDude05's Avatar
I have a T3/T4 60 trim and .63 A/R and running a .8 BAR (11.5) spring with 9.5 intercooled boost. So, 9.5 lbs gets me to 259WHP and 287WTQ. What the hell?
Old Nov 26, 2007 | 11:32 PM
You run a 11.5 psi spring but only read 9.5psi???
Where are you reading boost pressure at?
The place that did your tuning, did they have there own boost guage/setup or did they just go off of your guage?
Bare with me, there is and end in sight.
Regards-
Todd
Old Nov 26, 2007 | 11:40 PM
20tCDude05's Avatar
Well, don`t we lose boost because of the intercooler?
I don't want to run like 15lbs to get to my goal of 325WHP because I am on stock internals. I am reading boost pressure right by the throttle body I think. So, what should I do? Apparently, someone thinks I can get much more out of my set up, but I think I am pretty high in terms of boost.
Old Nov 26, 2007 | 11:52 PM
You shouldn't, at least not with your setup, but if you are it makes sense...don't ask..please
Ok first off....psi is not psi...if you were to run the GT3076R for example at 10psi its like running your T3 at 15psi....its the amount of air your are forcing into the motor that matters. A turbo (t3) flows x amount of cfm where turbo B (GT3076R) flows y cfm.
10psi is not high....your turbo has allot more in it. And your motor can take allot more. The motor is not rated to take a specific amount of psi....its all about the cylinder pressure where the motor or parts will let go.....good tuning is the key here.
If you are really seeing a 2 psi pressure drop you need a more efficient intercooler core. Especially if you plan on upgrading to a larger turbo..... and at this point if this is actually happening going to a larger turbo is just going to make things worse not better.
I have 2 recommendations....and they will save you allot of money at this point.
But your the boss so do what you think is best.
1- change to a more efficient core, you will make more power than you are already plus you won't see the pressure drop. (be interesting to see what you make at 11psi)
2- Start there, then lets talk about turning up the boost. But if you want to upgrade to a larger turbo you will need to take care of #1 regardless.
Enjoy!
Regards-
Todd
Old Nov 27, 2007 | 12:08 AM
20tCDude05's Avatar
Dang, another at least $500 just for another intercooler. Lemme talk to my friend first. He has a 620WHP Prelude and he is the one who installed my kit. Anyway, so should I just get a 3076R? Because my turbo seems baby-ish for what power I want.
Mightygnu's Avatar
Wow being that high above sea level hurts. I feel bad for you.
Old Nov 27, 2007 | 12:20 AM
20tCDude05's Avatar
Yea, so not sure what to do with the altitude issue.
Old Nov 27, 2007 | 12:55 AM
Mightygnu's Avatar
Move to Cali!
Old Nov 27, 2007 | 01:09 AM
20tCDude05's Avatar
Believe me man, I have thought about it. Hell, I`d move next door to you because obviously, you`re in a great level for that power, haha!
