Some supercharger questions
Old 11-26-2005, 02:12 AM
JohnL's Avatar
Default Some supercharger questions
This is my first post here so be easy on me guys... I've been reading over the threads for the past couple of days and I'm trying to soak up as much as possible, but I do have a few questions... (I have googled and searched this thread, slap me if i missed something)
1) Is there a published/electronic version of the install manual (if there is such a thing) for the supercharger? I am wondering if it is something that maybe I could tackle, but I want to look over the manual to see if its greek or not. I've changed an alternator and a starter on my current car (98 honda accord) as well as some brakework and the normal oil and such, and I want to see if this would be totally beyond me or not...
2) With the pulleys that ZPI is releasing, what kind of engine management would be needed to adjust the Air:Fuel ratio in the engine? would there need to be new injectors with that much more boost? I think their website says that they produce something like 1-2psi more than the stock blower, which would bring it up to a max of 9psi IIRC
I havent bought my tC yet, but I am dead set on one and I am already trying to figure my way through adding onto it... Thanks for the info in advance!
JohnL is offline
Old 11-26-2005, 04:19 PM
terra_tC's Avatar
well john i think the reflash that comes with the sc is good enough to run a smaller pulley from zpi, its only ~2psi and the injectors and ecu can probably handle it. Do some searching in this thread (ph) in the supercharging topics, especially the zpi pulley one. im sure youll find your answers.
terra_tC is offline
Old 11-26-2005, 04:30 PM
Scion-ce's Avatar
you can find the install manual at www.trdsparks.com
Scion-ce is offline
Old 11-26-2005, 04:33 PM
Lyracon's Avatar
zpi has come out and said that their pulley is safe with the SC reflash.
Lyracon is offline
Old 11-26-2005, 05:14 PM
hPower's Avatar
Hey John, welcome to the boards! I am a newbie here too but I have already learned some good stuff from reading around on these boards.
Here is a direct link to the file with the installation instructions
http://www.trdsparks.com/displaypart...3&parts_id=634
And for your boost question, you should be ok with the stock set up as long as you keep boost within 3 to 4 psi of the stock range. NST and ZPI are both doing some reseach and should have stuff available very soon for our cars. If I were you I would wait until both companies have stuff out before rushing into buying one, but thats just me.
Here is another good link for you
www.NonStopTuning.com
Good luck with your tC bro
hPower is offline
Old 11-26-2005, 05:55 PM
JohnL's Avatar
Thanks for the answers guys, it would figure that about 10 minutes after I posted, I found the manual at trdsparks.com... thats the way it goes I guess. But I looked over that manual a little last night and I think it is bordering on too much for me. I think if maybe I could get a long day in (start at 7:30 or 8am) that maybe I could pull it off, but I think I would need to invest in some equipment. Has anyone here done the install themselves? and if you do it yourself, does it bring your warranty down to 12mo/12K miles on the whole car (since thats all you get without a dealer install...)
Thanks
JohnL
JohnL is offline
bootlgr
01-26-2016 01:22 AM
Greg S
05-28-2015 12:46 AM
jairolla_89
04-02-2015 09:41 PM
Scionxa180
03-13-2015 04:39 AM
TotalChaos
13
02-04-2015 10:24 PM
Quick Reply: Some supercharger questions
