Someone help pleaseeeee!
Old Apr 25, 2012 | 09:28 PM
SoFloTC's Avatar
Default Someone help pleaseeeee!
EDIT: See my last post! Ignore this paragraph.
Ok so long story short heres the problem.
Was running AUTO ECU - Auto Harness w/ Manual swap.
Got tuned. Found out i need the resistor mod for the studder on FIC aswell as the auto harness relay to cut the battery power.
So whatever i get home and after everytime i park the car i unplug the FIC for now to stop the battery drain.
One morning i plug in the FIC and turn the car in the "ON" position AND THEN BAMMMM! sounded like a super loud backfire and saw smoke around the car. From then on, the car will *in the ON position* rpms move by itself from 0 to 2-3k and keeps going up and down. When i turn the car over actually start it, it DOES THE SAME THING and revs up and down and then dies after like 5 seconds.
Went and got a Manual ECU.... Same thing happening..... did the immobilizer trick and still happening.
Swapped my throttle body, still happening....
CAN SOMEONE HELP. WHY is it revving up by itself when in "ON" position or actually cranked over....?
Old Apr 26, 2012 | 08:13 PM
SoFloTC's Avatar
UPDATE. plugged in the manual ecu alone. without fic again. car turns on but REVS the exact same when on, NO longer moves rpms with key in "on" position but it revs the same when car is on but it actually STAYS on an doesnt die. i do smell alot of raw gas though.
Going to relearn the original auto ecu to the car now, and see what happens.
Old Apr 26, 2012 | 09:52 PM
SoFloTC's Avatar
on stock ecu and injectors it revs up the same and dies.
Old Jun 17, 2012 | 10:11 PM
browniemxn's Avatar
SoFloTC did you ever find out what happend with this? Sounds like you may have popped the ALT. Fuselink or the Alternator itself.
Old Jul 9, 2012 | 04:01 PM
stocksciontc's Avatar
I had a similar issue where my rpms would go up and down a while and then die out. It was a a bad fuel injector o-ring.
Checked for vacuum leaks?
Old Aug 29, 2012 | 09:56 PM
SoFloTC's Avatar
Bad injector o-ring? How did that cause that?
Old Sep 4, 2012 | 02:53 PM
Well when I was putting the fuel rail and injectors back on, I unknowingly damaged one of the o-ring on one of the injectors.
When I turned on the car, thats the symptom the car had.
I retraced my steps, and saw what I did. I got a new injector o-ring and it solved my crazy rpm issue.
Old Sep 4, 2012 | 05:11 PM
paul_dezod's Avatar
Scionetics
KAD
Because it's a vac leak at that point Chad.
Old Nov 20, 2012 | 06:45 AM
SoFloTC's Avatar
FOund out the revving was a bad MAP sensor apparently.
but the backfire still occurs with the FIC. not a clue why, but it always pops off the hose on the back of the head and smokes. compression is fine though... anyone know the cause of this>
xtC
9
May 20, 2011 02:42 AM
azndragon669
Aug 24, 2009 03:24 AM
CF_KC_WIDETC
Scion tC 1G Aero & Exterior
23
Jul 27, 2009 02:09 AM
boostedtc1215
Mar 10, 2009 10:43 PM
tcCALI
Apr 3, 2008 11:41 AM
