Stalling with FIC when coming to a stop? A quick fix!
Old Apr 29, 2009 | 11:45 PM
tC_2NeR's Avatar
Default Stalling with FIC when coming to a stop? A quick fix!
hey dudes
I was playing around today with my FIC and found a few things...
Try clicking on High Level Drive in the setup menu...and set the injector response time to ~1100.
My car RARELY bounces when coming to a stop anymore...and if it does its only about a 100rpm drop....
0 out your 02 map also in vacuum...
but be careful, if ur car was running okay and had the 02 map at 3.2 and ur fuel was setup nice, ur gunna have to change ur fuel tables to make up for 0'ing out the 02.
I have my fuel map in vacuum for idle at -42.2
(320/new injector size)-1 is the formula
i dunno if anyone else figured this out but i thought id share
Old Apr 30, 2009 | 12:08 AM
crush02342002's Avatar
yes someone already has...lol...Breal45 posted last week about it in the fic set up thread.
Old Apr 30, 2009 | 12:34 AM
tC_2NeR's Avatar
awesome im glad the word is out then!!!
Old Apr 30, 2009 | 12:38 AM
Ace83's Avatar
Ronin Scion
you guys go and spread the word!!
Old Apr 30, 2009 | 12:40 AM
maybe after i take a crap.....uhggg my stomack hurts
Old Apr 30, 2009 | 12:46 AM
Ace83's Avatar
Ronin Scion
^^ take some pics!
Old Apr 30, 2009 | 01:46 AM
we have a floater...bwwwahaaahahahahahahahahahaha
Old Apr 30, 2009 | 03:00 AM
Ace83's Avatar
Ronin Scion
hahahaha brown iceberg? you're gross man lol stop jacking this thread haha
Old Apr 30, 2009 | 03:31 AM
jjos1's Avatar
Default Re: Stalling with FIC when coming to a stop? A quick fix!
Originally Posted by tC_2NeR
hey dudes
What would be 3.2 on the o2 map ? bank hi voltage ? and will this work on v 3.01 ?
Old Apr 30, 2009 | 05:21 AM
Mrsanchez925's Avatar
this is exactly my problem! sweet thanks for the fix!
or it still might be my Crack manifold...
we'll see tho when i get the new one installed...
im dopping it fixes it!
Hoping****
Old Apr 30, 2009 | 06:07 AM
tC_2NeR's Avatar
As long as 3.01 has the option fo high level drive i guess itll work...3.2 is skewing the 02 map for a 14.7afr......but u haveto pull fuel in the fuel table to use 02skew for vacuum...
I tried using 3.2 with a -42.2 on my fuel and my stft went to --- 20%...ecu hadda pull 20% fuel...so i suggest keepin vacuum 02 zeroed out.
Old Apr 30, 2009 | 06:11 AM
oh ok ill talk to my tuner and see watsup.
Because my AFR's Bounce between 14.5- 15.2 when cruising and at idle also
like i said tho the reason i could be stalling out is because of the crack in the minfold thats letting out air....
Old Apr 30, 2009 | 06:12 AM
But the more Suggestions on what could be causing my stalling the better. so i know what to look for if the manifold wasnt the problem.
thanks
Old Apr 30, 2009 | 06:32 AM
tC_2NeR's Avatar
If ur crusin around and ur bouncin between even low 14s and low 15s ur A okay....
Just try setting the injector response time to around 1100 or 1000 and click on high level drive....
Thats the direct fix for the idle hunt
Old Apr 30, 2009 | 06:35 AM
tC_2NeR's Avatar
Plus i gotta give credit to BReal45...apparently he figured this out a while ago
Old Apr 30, 2009 | 06:37 AM
alright cool what size and type of injectors are you using??
Old Apr 30, 2009 | 06:39 AM
tC_2NeR's Avatar
Deatschwerks 550cc's
Old Apr 30, 2009 | 06:42 AM
alright same thing im running...
i wanna try doing this myself but ive never worked on anything liek this before so i dont feel like messing anything up.... so i guess i gotta wait to fix this... ugh lol
Old Apr 30, 2009 | 11:00 AM
i am really glad peeps are working on their own fic's and learning about em.....i only went so far with it and after i got a pro tune i stoped bothering with the fic...
