Supercharger installed, now the car wont start
Old Jun 27, 2011 | 06:59 AM
silvertc2005's Avatar
Default Supercharger installed, now the car wont start
Hello,
I have searched the forum and haven't found anything about the issue i'm having. Today I installed a supercharger on my 2005 scion tC. Everything appears to be hooked up the correct way but the car just wont start. The engine turns on then immediately turns itself off. Has anyone else out the come across this issue? I have no idea if it would be a fuel problem, ECU problem etc... If anyone out there has any feed back i would really appreciate it.
Old Jun 27, 2011 | 07:07 AM
crush02342002's Avatar
are you using any form of engine managment?
are couplers tight and sealing?
is the maf fully seated with o-ring in place?
is maf connected?
did you happen to leave the vent hose connecting to the pcv off while you were putting in the injectors?
are injectors fully seated with no fuel leaks?
Old Jun 27, 2011 | 02:01 PM
thendawg's Avatar
Also, did you swap in an ecu from a diff car? If so, you need to learn it to your car, if you didnt this is exactly what itll do.
Old Jun 27, 2011 | 03:15 PM
Syldrin's Avatar
double check to make sure your fuel injectors are clipped in.
Old Jun 27, 2011 | 10:25 PM
Rockztar's Avatar
did you get the ECU flashed?, check the maf is properly installed...
edit: also if you are using an ecu from another tC then this is what happens
Old Jun 27, 2011 | 10:47 PM
garynkim's Avatar
also check your wire to the crank sensor i think it was extended for it make also make sure its not pinch too. also check the vac. line that goes from valve cover to the supercharger too.. on top of what everyone said.
Old Jun 28, 2011 | 12:59 AM
Thanks for the advice but i found the issue. after we did the install we forgot to do the paper clip trick on the ECU to register it to my car.
Old Jun 28, 2011 | 11:47 AM
glad you got it worked out...happy boosting
Old Jun 28, 2011 | 03:09 PM
Thanks a lot. I am enjoying the boost. I am running the supercharger with the NST 9.5 pulley
cid_mcdp
Jan 5, 2015 02:45 PM
06ScionTc5sp1
18
Dec 21, 2014 07:21 AM
minter66
Dec 15, 2014 01:45 PM
BV19869
Dec 11, 2014 06:05 PM
Monkeywrench
Aug 11, 2004 02:55 PM
