Supercharger Rebuild DIY - Part 1 (Shaft Seal and 1 impeller
This little DIY is going to cover my journey from initially changing out my shaft seal to having to change an impeller bearing aswell as some other huge bearing. When I get the impeller bearing ill post up pictures of the part number. Its a 17x35x10 bearing though.
When I wrote this guide I already had the blower out of the car so just bear with it. I took pictures of what needs to be disconnected and unscrewed. Tools Required: 8mm Wrench to take blower off mounting brackets 13mm 12 pt socket HondaBond (Best stuff ever) Hammer Screwdriver Rags I think 14mm wrench to get off oil feed lines Step 1: Remove the 3 Allen bolts that thread from the shaft to the supercharger. Also dont forget to remove the oil feed line and the oil return line aswell as all the hoses and tubes connected to the blower. http://www.importatlanta.com/upload/...7/CIMG0844.JPG Step 2: Remove the 3 8mm Bolts underneath the charger that hold it to its bracket. http://www.importatlanta.com/upload/...7/CIMG0845.JPG Step 3: Remove the 13mm 12pt bolt. This is what caused me all the problems with the bearings, not removing this first. It took a 550ft lbs Impact gun to bust this bolt free. http://www.importatlanta.com/upload/...7/CIMG0846.JPG http://www.importatlanta.com/upload/...7/CIMG0847.JPG http://www.importatlanta.com/upload/...7/CIMG0848.JPG Step 4: After the bolt comes out you can slide out this black thing. Dont lose its little square key though. http://www.importatlanta.com/upload/...7/CIMG0849.JPG http://www.importatlanta.com/upload/...7/CIMG0851.JPG Step 5: Loosen and remove all the little bolts surrounding the supercharger. I have them loosened in this pictures. If you dont seem them here loosened dont take them out!! http://www.importatlanta.com/upload/...7/CIMG0850.JPG Step 6: If you look in you can see the seal. Seperate the 2 halfs of the compressor. Be very very careful that you dont put ANY stress on the bearings that are pressed in. After you should be stuck with 2 pieces of compressor, one side filled with gears, the other filled with 2 bearings and a seal. Do what ever it takes to get the seal out. Then with you new seal in hand run a nice ring of honda bond around the outside of it and press it into where the old seal was. http://www.importatlanta.com/upload/...7/CIMG0852.JPG This is what you should be left with. There should be a bearing though where the little 20 is written. (Thats where mine broke from) http://www.importatlanta.com/upload/...7/CIMG0853.JPG Rest of the pictures are just of the inside of the blower. To reinstall do the reverse of the take apart sequence. http://www.importatlanta.com/upload/...7/CIMG0854.JPG http://www.importatlanta.com/upload/...7/CIMG0855.JPG |
Wow, nice job Kik... Very good work.
good job kik
very nice man!
post the second part in this thread... so not to make another thread and have it all in 1 place. |
Yep thats the plan after I get the bearings in. Im going to edit the first post.
What speed rated bearings did you end up getting ? where you able to get the abec 9 s ?
I ended up getting the abec 7's, they are speed rated to 58,000 rpm. I figure though, this car isnt making near the 22 pounds of boost its capable of so its not going to be spinning near that fast. Ill be good up till about 12 psi or so.
nice work!
Yes, thanks for posting, this needs to go in the tech section.
How was pressing off the bearings, pita ? are you doing the shaft bearings also ? just so you know all the shaft bearings are skf 6205 c3 bearings ( 4 Total ). The ones inside the compressor are open cage make sure they are not packed with grease and if they are you need to clean them completely you do not want any grease inside the compressor. |
nice
Well as it turns out if your going to be running 9.5 pounds of boost you will need 30875 RPM @ 9.5psi speed rated bearing seeing as for every pound of boost the blower is rotating at 3250RPM. I didnt change all the bearings just the impeller shaft one and 1 of the skf 6205's
pics not working. :(
yeah i cant see em either
post back from the dead! im thinking about doing this soon, pics dont show up but thanks for the write up kik.
| All times are GMT. The time now is 07:20 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
