tapping oil pan q's
tapping oil pan for oil return on a turbo, where should the tap be approx from the top of the pan? and should i weld the return or just tap and dye it?
im tapping for a greddy kit if that makes a difference.
If you don't have access to a welder, you can brilo the area around the fitting and use some JB Weld.. it works wonders.
I've actually fixed a decent sized crack on an engine block before with it.
Wrencher
Mar 12, 2023 04:54 AM
