tc not running right after installing s/c
ok i got a trd supercharger for my 05 tc. i put it on myself. i when by the book when it came to installing it. took my ecm out to get reflashed. but now i'm having problems. first it will not got up to 6200rpm it cut out at 5500. second when trying to maintain a speed limited it sputters really badly. need some helpfully information on trying to get it running right...thanks
Thats alot of rpm. Maybe shift prior to 5k, I dont see a reason to go above that, other than to blow a engine. The car should run a little on the rich side, atleast mine does with the s/c.
OP, is your ride throwing a check engine light? Not sure if this would help but have you tried disconnecting the battery for a few mins and then allowing the vehicle to idle?
My suggestion like above stated, make sure the injectors are seated properly. I had this problem and my motor wouldn't go past 4600 and then my car cut off.
And to Dunn, where does he even talk about "bouncing" off of the limiter? If i'm reading correctly, he says he can't shift past 5k. And just because someone shifts past 5k, doesn't mean they bounce. There are some people out there that aren't bad drivers ;)
you know how if you hit the rev limiter(if you keep you foot on it) and it will stay there and bounce off of it.....well at 5500 the motor just dies, the rpm will drop until you lift your foot and hit the gas again. but it will not go past 5500
