Testin internal Wastegate on Greddy Kit...
Old Jan 7, 2007 | 02:47 PM
Crippie's Avatar
1UP Crew
Default Testin internal Wastegate on Greddy Kit...
Hey all... anyone know how to test the internal wastegate on the greddy kit... would like to be sure its alright before i install... Thanks
Old Jan 7, 2007 | 03:34 PM
zer0's Avatar
Take a pic of the WG Actuator and post it up. Its a start. Make sure its not bent out of the ordinary.
Old Jan 7, 2007 | 03:58 PM
ERIC-TC's Avatar
The actuator is what get's messed up in shipping. If you can open and close the actuator by hand and it feels smooth then it should be okay.
Old Jan 7, 2007 | 06:24 PM
Joe_Dezod's Avatar
If the actuator rod is free of defects and you can't find any other physical damage you should be ok.
When you first drive... Make your first boost pull in 5th gear at about 2000rpms. Floor it and you'll have time to let off if the boost levels go too high. Do not do this often though. Putting a severe load on the motor in a high gear at low rpms is not good for it in long-term.
Old Jan 7, 2007 | 06:53 PM
Crippie's Avatar
1UP Crew
These are the pics i took... i didnt see anything out of the ordinary and after i manually moved the actuator, it seems like its ok... here are the pics:
thanks for your help guys
[/img]
Old Jan 7, 2007 | 07:07 PM
Joe_Dezod's Avatar
Looks pretty good to me man. I'd do the test I was telling you about and let us know how it goes. You should be fun.
Old Jan 7, 2007 | 07:11 PM
Crippie's Avatar
1UP Crew
i tried what you said, and with some pressure, i was able to get it to open ... i think its alright... ill cross my fingers... thanks Joe and zer0
Old Jan 7, 2007 | 09:06 PM
toyotaracer9's Avatar
if u want to be 100% sure it will open at a specific pressure u will need an air supply with a low pressure gauge and regulator . turn the reg. down while having the airline plugged , once u get the pressure to ur liking then hook a hose to the port on the waste gate actuator and the pressure regulator , it should fully open at that specific pressure .
Old Jan 9, 2007 | 03:25 AM
etsnet's Avatar
That's good to know. Another bit of knowledge to add to the brain.
SloTC1
Aug 16, 2018 02:45 PM
tckid21
Jan 9, 2016 09:19 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
Mpwr
Jul 17, 2015 08:39 AM
