To those with hard pressure plates!!!
This is why Supras get crank walk all day long. I am putting in a stock disc and using a stage 3 pressure plate in my supra and it is supposed to handle 500 tq until I have enough for a twin or triple disc clutch. but yeah..... I would seriously recommend to everyone to stay away from high pressure pressure plates. stg.3 plates with like a stage 4 disc should be fine for most ppl making high numbers here on the forum.
The pressure plate either with a sprung or unsprung disk. Doesn't matter. 4 puck or 6 puck. Doesn't matter. Pressure plate was culprit and maybe bearing also. Act does have the highest rated disk clutches but comes with a price to pay. The street pressure plate which is only 30% pressure over stock is good. And rated to 545trq.
http://www.dezod.com/cat-clutch-sets.cfm
where did you find this act clutch that only has 30% pressure overstock but hold over 500tq? the one on dezod is 70% over, rated 504 tq
http://www2.advancedclutch.com/14328...I_(2AZFE).html
i used to have part number T023X clamp load 70% and rated at 645trq
I have a very very very stiff pressure plate and I had absolutely no crank walk!!! Sounds to me that the installer of the bearings didnt install the right ones!!! I wouldnt blame the pressure plate as I can guarantee that my pressure plate is ALOT stiffer than that ACT as I have dual Diaphragm springs for the extra clamp load. If you want a less pressure plate and a still have the holding power you need to change the disk out to a 4 or 3 puck. The lesser amounts of pucks the greater the clamp load. Reason being is that more PSI will be distributed to each puck thus allowing for it to grab harder.
A twin disc shortens the input shaft life of the tranny. Thus the reason why Ptuning had problems with 4th gear (1:1 gear ratio). A twin disk is a little over kill for road racing and I dont see a need for it just yet. I have a custom made clutch 4 puck un-sprung disk, with a dual diaphragm spring pressure plate.
What's actually breaking 4th gear or even 3rd gear is 500+ wtq shearing the teeth of the drive and driven gear, the gears fail while in gear not during shifts. We contribute the problem to the factory gear metalurgy as well as thermal stress due to the shear amount of heat generated by the enormous load on the M/T. But we are working on a solution for the weak factory M/T for next season.
MrC
How does the twin disc shorten life of the input shaft? If anything the twin disc actually reduces premature thrust bearing failure due to lower spring rate on the pressure plate vs a single disc of the same tq capacity. No single disc setup is going to compare to properly designed twin disc like the exedy twin or even the CM twin that we ran before, in terms of light pedal pressure with high tq holding capacity.
MrC
MrC
I have seen increased wear on some subaru and EVO transmissions using twin and triple discs. This is caused by additional discs riding the shaft. The small movement of the discs on the splines distort the splines over time.
However I'd run a twin disc any day over a single for the main reason this thread was made. Semi trucks make tons of torque. They run 6 to 7 disc clutches. It's unfortunately the way it is. In order to have the ability to transfer all that power and not destroy engine parts or clutch hydraulic parts there is a trade off. Cost and wear. I haven't heard of wear on Scion transmissions but we don't exactly have many people using twin discs either.
StreetStandard
Jun 28, 2015 06:26 PM
Bmfxtreme
Jun 22, 2015 02:25 PM
