transmission issue on 341.1 whp 301 ft lb???
Old Jun 15, 2011 | 12:16 AM
troy2003's Avatar
Default transmission issue on 341.1 whp 301 ft lb???
O.K., my car runs flawless and i replaced the stock clutch to an exedy stage two upon advice from ptuning since thats what they run. With that said i have noticed that in fifth gear at about 80 mph 2800-3000 rpm range, when i go wot, my car builds boost, rpms rise; however the car stays stationary at 80 mph, gradually just coasting. I replaced the clutch to exedy thinking i was making too much power for the clutch, well i know i was anyways, what do i look into next?, axles??, what transfers power from our transmissions to the wheels?, is it possible my issue lies there??. with all of that said, im on a pretty good power curve, gradually making hp through the rpm range and making the bulk of my hp at the top of my rpm range.
printout of power band, ending at 341.1 to the wheels
Old Jun 15, 2011 | 12:20 AM
rangerryda's Avatar
You're spinning the tires!!! lolz That sounds weird man.
Old Jun 15, 2011 | 12:27 AM
troy2003's Avatar
ummmmmmmmmm, no, in fifth gear at 80 at about 2800-3000, when i go wot, the car builds boost, rpms rise; however the car just coasts, and power doesnt get transferred to the wheels, thats the only time it happens, every other gear at wot the car grabs and pulls like a raped ape.....any thoughts, input adice??
Old Jun 15, 2011 | 12:47 AM
brett561tc's Avatar
its 5th gear at low rpm. why are you so surprised?
Old Jun 15, 2011 | 12:55 AM
troy2003's Avatar
3 grand in fourth and third do not have this issue, so what you said spelled out is - this is to be expected in 5th gear at 3 grand??
Old Jun 15, 2011 | 12:56 AM
troy2003's Avatar
and keep in mind man, the car is doing NOTHING, no power is being transferred, that just doesnt seem run of the mill to me. I build all the way up to 11 psi and the rpms rise, but nothing happens, the car just coasts...so your saying this is normal??
Old Jun 15, 2011 | 12:59 AM
Syldrin's Avatar
troy. what he was saying was a joke. you know lol it was funny.
Old Jun 15, 2011 | 01:04 AM
troy2003's Avatar
hahahahaha, awwwww, brett i see what you did there....excuse my special moment in time where i went full retard for a minute. lol
Old Jun 15, 2011 | 01:07 AM
Syldrin's Avatar
i ment ranger. not brett.
its a really weird case it sounds like you have a defective clutch but i don't understand how it could do this and hold in other gears.
i have a similar problem in 4th except i move a little still.
why not pull the end cover off to make sure nothing is wrong with 5th?
Old Jun 15, 2011 | 01:09 AM
trd07tc's Avatar
act ftw
Old Jun 15, 2011 | 01:11 AM
troy2003's Avatar
if that ends up being what the general thought is within this thread i will have that done, it sucks cause any time i need any type of work done it has to go to my shop, cause i dont have the room or tools to get the job done...next time i deploy or go tdy i may just have my shop crack it and take a look to be safe....im just mad confused.
brett561tc's Avatar
so you can hold your foot to the floor in fifth, build 11 psi, have the rpms hit the rev limiter, and your car will stay at 80 mph???
Old Jun 15, 2011 | 01:16 AM
troy2003's Avatar
i get too worried to let it run to redline, it gets to the point where i see the gauge read 11 psi, and i get out of the throttle.
Old Jun 15, 2011 | 01:22 AM
brett561tc's Avatar
make a video of what you are talking about with your phone. you may just be letting out before you start to get in your powerband. 5th is an overdrive gear so it will lag. try to stay in it till redline, and hold the phone back enough so that we can see the tach and speedo. if there is something wrong with 5th gear it will show on the video as well.
Old Jun 15, 2011 | 01:30 AM
troy2003's Avatar
cool, well im airforce in texas for training, get back in 2 weeks though, ill get videos, and bump this thread then, so you guys can get a better idea.
Old Jun 15, 2011 | 01:32 AM
Syldrin's Avatar
where are you stationed?
Syldrin's Avatar
ah nvm
Old Jun 15, 2011 | 02:38 AM
TCpete's Avatar
if your revs are rising and your speedo is not... its either the clutch or something in your 5th gear... pay attention to speed @ 3k to 6k... if your not accelerating then its clutch or 5th gear related.
Old Jun 15, 2011 | 04:20 AM
Syldrin's Avatar
Pete I hated on you in brains thread.
Sent from my DROID incredible
Old Jun 15, 2011 | 02:04 PM
TCpete's Avatar
lol... haters gona hate
