Trd Reflash + intake = lean?
Old Jun 20, 2010 | 04:55 PM
Datswhtshsed's Avatar
Default Trd Reflash + intake = lean?
i have been reading some threads on here and a couple in other forums. the issue of running lean by running an intake on a trd reflashed has surfaced but never really explained or discussed in details. i know of one person that made this claim and everyone else seems to follow him. But i want to make sure that it is true.. what is your take in this? I am going to be buying a SRi for my SCed tc.
Old Jun 20, 2010 | 05:25 PM
oh. i will also be running the 9 psi pulley.
Old Jun 20, 2010 | 07:02 PM
gwtc's Avatar
There are many people on here who ran/are running intake and 9.5 pulley and were getting good A/F readings(it will vary depending on where you live, exp: temps & elevation), the best thing would be to have an A/F gauge installed before you do it, that way you can monitor it as you upgrade, the reason it seems to be ok is because the TRD re-flash tends to be a bit rich so adding a little more air does not hurt ti too much; good luck and hope that helps.
Old Jun 20, 2010 | 10:18 PM
thanks brotha! can you pose some link that i can look into? i will greatly appreciate it. i am new to the site and still trying to figure out how to navigate.
Old Jun 21, 2010 | 01:48 AM
gwtc's Avatar
Here you go:
https://www.scionlife.com/forums/sho...ake+9.5+pulley
Remember that not everybody has had the same experience so what would be best for you is to get an A/F gauge installed just to be on the safe side, hope that helps.
Old Jun 21, 2010 | 03:48 AM
b52hDUNN's Avatar
Mine runs just fine. I have a wideband and get good numbers.
Old Jun 21, 2010 | 06:24 AM
^^^ hey i think i have seen your videos on youtube. how is your car dealing with running a BOV? are you having a hard shift when venting?
Originally Posted by gwtc
Here you go:
thanks bro. i really appreciate you posting these
Old Jun 21, 2010 | 08:53 AM
b52hDUNN's Avatar
^ yea thats me. The hks bov works well with my setup, no issues at all.
Old Jun 21, 2010 | 07:13 PM
paul_dezod's Avatar
Scionetics
KAD
The air flow was calculated based upon stock air box and it's restrictions, so if you added airflow, you then altered that equation, which means in theory it will be leaner. The system may not throw a code for it, but it will undoubtedly alter the fuel trims all together.
Old Jun 21, 2010 | 07:14 PM
paul_dezod's Avatar
Scionetics
KAD
What AFRs are you seeing during cruise and WOT? Also, running a cat on your car?
Old Jun 22, 2010 | 08:37 PM
SciMeiji's Avatar
+1
Old Jun 22, 2010 | 09:37 PM
Thanks paul. IYO its safe to run the 9.5 with an sri for a DD? i am not really looking into racing. maybe just a couple of hard driving here and there.
Old Jun 22, 2010 | 11:05 PM
b52hDUNN's Avatar
Numbers are while Im driving so there close to actual.
IDLE 15.3
PARTIAL THROTTLE 14.5
3/4 THROTTLE 12.0
Old Jun 22, 2010 | 11:28 PM
SciMeiji's Avatar
IDLE 15.3
3/4 THROTTLE 12.0
Correct me if im wrong but dont those numbers seem alittle on the lean side?
Old Jun 23, 2010 | 12:53 AM
paul_dezod's Avatar
Scionetics
KAD
IDLE 15.3
3/4 THROTTLE 12.0
idle is pretty lean. Should be in the 14.4-14.8 range
part throttle, define part throttle 10%? 30%? 50%?
3/4 throttle seems a touch lean for what will preserve the cat and run well on this car and not have a huge propensity to knock
Old Jun 23, 2010 | 02:46 AM
b52hDUNN's Avatar
Like I said this is looking at the gauge while driving. Numbers aren't going to exact like a computerized afr graph since they change so much.
Ill see if I can get some more numbers in the next few days.
Old Jun 23, 2010 | 06:16 AM
dopes dumping the air by using the BOV minimizes the car to run lean? ( i figured it doesnt since the BOV is closed when the throttle is open)
Old Jun 23, 2010 | 09:55 AM
b52hDUNN's Avatar
Actually it makes it run rich for a split second when it dumps.
Old Jun 24, 2010 | 01:59 AM
figures..
airmankevin1
Feb 14, 2018 01:23 PM
Greg S
Jul 21, 2016 07:28 PM
danielv
Aug 26, 2015 07:14 PM
JPuehl
Jan 10, 2015 01:01 AM
minter66
Dec 15, 2014 01:45 PM
