Tuning with EGT's
Anyone have a recommended EGT gauge brand and type to get accurate and reliable readings from? It was next on my list of things to buy anyway
Very informative thread. Me likey.
Your EGT sensor should be placed no more than 2 inches from the exit of the cylinder head exhaust port. It should be placed on the hottest cylinder.
Typically and keep in mind many factors effect this, idle should be around 850-1000F, cruise 1300F, WOT no more than 1725 F.
Volumetric efficiency plays a key role in EGT and thus affects timing and other things.
While on boost though I think the difference would minimal regardless of bung placement on the manifold since exhaust velocity and volume will be more but we will have to see as soon as compare the numbers
you should be fine with defi, aem or autometer. Prosport is ok but my recent purchase with them is a bit disappointing.
which cylinder would be the hottest? its gonna be cylinder 1 usually right? Im gonna put an EGT bung closer to the block and see how much difference it makes..
I have never tried tuning anythin with EFI using EGT. Done quite a bit on mechanical alcohol systems and some on carbureted gas stuff. On the carbureted stuff I have found that usually the owner has richened the thing so much it fouls plugs and runs at 10.0 AFR while chasing EGT's. So I would recomend also using a wide band O2.
The installation instructions for the EGT shows how close to put it, if I remember right its 1" - 1 1/2" from head. It will not matter which cylinder if the engine is running correctly all of them should have identical EGT's or be very close.
To an extent, factors such as throttle body placement, intake runner flow, heat soak, cooling jacket design all play roles on how hot a cylinder runs.
I spoke to a guy who has his EGT probe right on the downpipe close to the turbo exit and his EGTs are like 500-700 on normal driving city/highway its like 200-300F less than mine which is before the turbo inlet. I would assume my actual egts on the cylinder would be roughly 200-400F more than what my gauge reads.. but ill wait till i get a bung closer to the head to actually measure it
vi3tb0i09
Sep 23, 2015 08:32 PM
