Turbo Checklist
Old Jan 18, 2008 | 01:32 AM
bruceg's Avatar
Default Turbo Checklist
Ordering everything sometimes next month if everything goes as planned. Made up a little list with prices and all...please let me know if I am leaving anything out!
Glow Shift Gauges:
-Oil Press.
-Boost
-Tripple A Pillar grey guage pod
$115
Dezod Motorsports:
-NGK Iridium spark plugs (two stages colder than stock)
-Clutch (ACT Street Clutch)
-AEM UEGO 6 in 1 Wideband guage
$750
Stage 1 GT Kit from Turbo Toyotas.
Includes the following:
-Hand Welded Stainless T3/38 Equal Lenth Turbo Manifold
-Garrett GT28RS Disco Potato Ball Bearing Oil/water cooled Turbocharger
-2.5" Stainless downpipe/s pipe
-Tial 38mm wastegate with dump tube
-Tial 50mm Blow Off Valve
-2.5" Aluminum charge piping w/hoses and t-bolt clamps powdercoated black
-3" Intake pipe with air filter powdercoated black
-22 x 7 x 2.25 Intercooler
-Turbotoyotas Vacuum log with fittings
-Oil feed and return lines
-Water feed and return lines
-Hardware and Installation Instructions
$3,899.00
Fuel Management from Turbo Toyotas.
-Greddy Emanage
-Plug n play adapter for Emanage with ignition and injector harness
-RC 550cc Injectors
-Greddy Pressure sensor w/ harness
$995.00
TOTAL: $5759
Of course this is not including nick nack stuff and tuning price and changing oil and filter. Which brings me to a few questions. One: How much extra oil should I put? (People say to put a little more since u can use the extra oil for supplying the turbo and all.)
Second..where can I buy all the sealants and all that is needed for the installation? Anywheres online? I've asked around town and I get looks like I'm a retard.
Old Jan 18, 2008 | 01:45 AM
BrownDogg's Avatar
Sounds awesome to me! Cant wait to see everything installed
Old Jan 18, 2008 | 02:06 AM
Mr_Meaty's Avatar
Good list.
I put in another 1/4 to 1/2 a quart extra of oil.
The sealant for the oil pan you should get from the toyota dealer (if your tapping it yourself, which I DON"T recommend) cause that stuff is the best.
For the other oil fittings and what not, get the red RTV high temp silicone sealant. it comes in a tube at autozone or pepboys or wherever.
And don't forget to start putting 91 or higher octane in yoru car for at least 2 fillups before you install your turbo.
Old Jan 18, 2008 | 02:15 AM
java09's Avatar
yeah it appears youve got everything down. and phil said just about everything else, damn you phil i was gonna tell him!
Old Jan 18, 2008 | 02:17 AM
bruceg's Avatar
So from then on I need to always use 91+ octane fuel?
Old Jan 18, 2008 | 02:22 AM
java09's Avatar
yes to prevent engine knock/detonation.. you need the higher octane under boost.
Old Jan 18, 2008 | 04:43 AM
BuddhasTC's Avatar
also i would rethink the glowshift gauges as they're not accurate. For boost, i would definitely wanna get something a little more accurate...autometer, greddy, hks, defi...there's a lot of companies. also make sure it's a boost/vaccum gauge...can tell you a lot when problems arise
Old Jan 18, 2008 | 05:31 AM
java09's Avatar
yup like vaccum leaks and such
Old Jan 18, 2008 | 06:06 AM
Mightygnu's Avatar
First of all, it would be wayyy cheaper to get everything from Dezod. Believe me.
Second, don't go with glowshift gauges, they do not read accurately, might as well pay to play and be safe.
Third, Go with Dezod once again, it will be cheaper!
Old Jan 18, 2008 | 12:12 PM
bruceg's Avatar
I'm not aiming for being cheap...I want the Turbo Toyotas Kit for sure..just not completely set on whether or not I'll get my engine management from there or not.
Old Jan 18, 2008 | 05:07 PM
Mightygnu's Avatar
I do not see why you won't get everything from one company...
I don't see the reason in spending excess money when the results will be similar.
Old Jan 18, 2008 | 05:18 PM
BrownDogg's Avatar
Well I do... because he wants the turbo toyotas kit. Its like having two cars that are really similiar in price and performance. But you like one that u think is better but the other person wants the other car. But he likes the rims on the car you like... Its that simple. haha. well that analogy worked in my mind
Old Jan 18, 2008 | 05:19 PM
fdkumro's Avatar
x2
Old Jan 18, 2008 | 05:44 PM
java09's Avatar
todd hooks it up with deals the same that dezod does so im sure todd can work something out with you to keep you with buying from him!! all you need do is ask him!!
Old Jan 18, 2008 | 05:52 PM
paul_dezod's Avatar
Scionetics
KAD
Absolutely. Drop me an email and I will quote you. (be sure to include all you need)
Old Jan 18, 2008 | 06:01 PM
Mightygnu's Avatar
I am not saying that Todd does not have competitive prices with Dezod, not at all. They are both reputable companies. I have dealt with both of them, and talk to them all the time. I was just simply recommending buying everything from one company as you'll probably save a buck or two.
Old Jan 18, 2008 | 07:36 PM
2_much_tc's Avatar
why don't you get the AEM F/IC? It's obviously been stated that it out performs the Greddy Emanage Series. And you wouldn't need that pressure sensor. That would save you some cash there too...
Old Jan 18, 2008 | 07:48 PM
java09's Avatar
no prob man, i know you meant well i was just saying since the majority of the money will be spent with todd because of the stage 1 kit he might as well one stop shop.. you have adezod kit and naturally pull for dezod more and i have a TT kit so i pull that way.. its all in the respect you have for your company!! i recommend TT then dezod, you recommend dezod then TT, if not recommending either one at the same time!! both bad ___ companies and i love my dezod exhaust! TT+dezod= get the fluck out of my way!!!!!
Old Jan 18, 2008 | 11:02 PM
BuddhasTC's Avatar
i recommend checking out www.egauges.com...good prices on the autometer gauges
Old Jan 18, 2008 | 11:12 PM
Ace83's Avatar
Ronin Scion
yup I would say no to glowshift, its better to buy a used but good gauges than glowshift.. ^^ egauges will better option.
