TURBO ENGINE BUILD
Old Apr 26, 2011 | 03:43 AM
loroku's Avatar
Default TURBO ENGINE BUILD
so im looking to build my engine do i need to re do the sleeve or can i get away with just pistons rods and bearings and a hone?
Old Apr 26, 2011 | 04:02 AM
trd07tc's Avatar
What are your goals for the car?
Old Apr 26, 2011 | 04:16 AM
loroku's Avatar
400 to 500whp
Old Apr 26, 2011 | 05:33 AM
Ace83's Avatar
Ronin Scion
you are good without sleeves
Old Apr 26, 2011 | 06:28 AM
loroku's Avatar
also do i need arp main studs? when do the stock units fail?
Old Apr 26, 2011 | 09:21 AM
crush02342002's Avatar
think of arp main studs as extra insurance...I dont think anyone can tell you an exact number of when the stockers will fail. I built my engine with just the bare essentials, pistons, rods, bearings...everything else was pretty much oem or oem replacement parts I should say.
Old Apr 26, 2011 | 02:00 PM
Ace83's Avatar
Ronin Scion
^ what he said.. since you will be running much more cylinder pressure its better to have stronger studs.. there are tons of variable that could lead to studs failure biggest factor is the tune and amount of power you are running.
Old Apr 26, 2011 | 02:15 PM
brett561tc's Avatar
i would get head studs for sure. main studs only if you really plan on revving the crap out of it.
Old Apr 26, 2011 | 02:22 PM
tom0613's Avatar
^^^^ what he said, I have seen a few tc here with above 450 whp and revving to 7500 on stock main studs and these cars are there daily driver.
Old Apr 26, 2011 | 04:04 PM
trd07tc's Avatar
what type of fuel will you be using?
Old Apr 26, 2011 | 07:40 PM
loroku's Avatar
93 octane maybe e85 depending on funds for my fuel system probally a dual tune one on e85 and one on pump
Old Apr 26, 2011 | 08:38 PM
vettereddie's Avatar
Don't forget the exhaust manifold studs when you hang the turbo. the stock bolt / studs do not cut it.
tcer904
Feb 25, 2015 08:12 PM
xa007xa
Feb 22, 2015 03:05 PM
carid
Feb 12, 2015 11:54 AM
k1114
Nov 30, 2014 01:40 AM
ScionLife Editor
Nov 25, 2014 03:00 PM
