Turbo help plz!!!
if its a true ZPI stage 0 then it should run "ok" without management, its not recommended, but not absolutely necessary when only running 4-6 pounds of boost, but be careful with those spikes, they are definitely dangerous!
lots and lots of things can make you boost higher than what the spring is rated for..
1. vac leak to wastegate
2. fittings on wastegate not sealing
3. pinched hose to wastegate
4. using crappy vac hose to wastegate that when it heats up it collapses or pinches
5. cheap wastegate
6. cold weather can make you boost 1-2psi over wastegate spring at times
just to name a few.
5. cheap wastegate
just to name a few.
SloTC1
Aug 16, 2018 02:45 PM
CrowJenkins
Oct 9, 2015 10:47 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
