Turbo Install Help
Turbo Install Help
we recently installed a Turbo Kit ( custom ) on a A/T TC. Turbo kit is on, no leaks, but when u try to drive the car and it's start hitting boost the revs stop around 4.5k rpm and the car dies. We're using a stock ecu. Are we missing something? or does it need some type of fuel/engine mgnt?
Originally Posted by BOXMAN
^^ the reason I posted "Ha" is due to a "Novice" getting in over their head. Things need to be thought out before you go head first into the deap end
As I stated go call the number I posted above. The reason I posted "Ha" is look how many "dumb" questions we get about boost a day on SL.... its a ton isnt it? Well maybe a guy shouldnt be making a "custom" kit for a car he has no clue about.
One more thing the Tc doesnt have a MAP sensor.... I take it you are a honda tuner?
Its ok I was being an azzhole to. I just hate how boost has a bad name due to people diving in before they should. He should be fine to drive just keep it out of boost. Put the smallest wastegate spring in and tell them to keep it under 4k. Also dont hessitate to call that number I posted they will set you right.
