Turbo tC running slow... need help
Hey fellas,
hope everyone's having a good sunday...
This Question is for the more serious turbo owners.
Well recently my tC hasn't been performing very good. I can feel that its slowed down.
earlier it used to brake traction in 2nd gear and sometimes in 3rd.
Now its not packin that punch.
earlier I used to feel the terror accelerating in 3rd gear.
now it just feels like a V-8
its been like this for a week or so now but today it started performing like before for a couple of miles and then got back to the V-8 feel.
I suspect its the spark plugs.
I am takin her to Ptuning tomorrow for the oil change and diagnostics.
BTW im runnin a Greddy Kit and 2step colder spark plugs.
should I run one step colder? My numbers are 258hp/273tq by Ptuning's load dyno. (baseline 137hp/150tq)
thanks fellas
also I dont need any sort of bashing on my numbers or my setup. I am running a great setup and dont need any thread jacking. thanks
thanks fellas
Originally Posted by tainoxl
Could be a number of things, bad plugs, exhaust leaks, clogged exhaust, dirty filter, low compression in your motor. Do a compression check then go from there. Nice TQ btw.
I have a lot of popping and I Shoot flames a LOT! maybe im running lean... idk
thanks (tq) I always filled up on Premium- my pocket hurts, but my lead foot feels good.
If I were you pop the hood and check all your lines, vaccuum boost etc. you might have a leak, do you have a boost gauge? If so try nd remember what you nornally boost at and see if maybe your boost is low that could be a problem, if not then wait for ptuning to diagnose it they'll know what to do
well I have a 3pm appointment... I'll let you know what they say
just another fyi-
I used to get 270-300miles to the tank... (well the 12.xx gallon mark)
now im getting 230-245miles to the tank.
thats why I think the spark plug/s may not be firing right so not all the gas is burning.
Originally Posted by yeldak
If you're shooting flames you're most definetely not running lean.
I always thought that if the car is runnin lean then it has excess gas exiting the exhaust- causing backfire.
guess u learn something new everyday
Could be a number of things, bad plugs, exhaust leaks, clogged exhaust, dirty filter, low compression in your motor. Also worn clutch. Do a compression check then go from there. Nice TQ btw.
filter is clean, don't remember the compression ratio.
got a brand new clutchmasters stage 4 clutch and lightweight flywheel like 6000miles ago.
I hope its the spark plugs.
U think I should go for 1 step colder instead of 2 step colder plugs?
10+ = 2 step
which is what i was supposed to be running then i brought it down and my car ran like ____. i thought it was the tune but turns out hte plugs got fouled.
fuel wasn't burning all the way and it fouled hte plugs.
Originally Posted by aen
10+ = 2 step
which is what i was supposed to be running then i brought it down and my car ran like poop. i thought it was the tune but turns out hte plugs got fouled.
Well I'll see what Mike at Ptuning says... and I'll keep u guys posted.
Ait guys,
Took her to Ptuning...
she threw 11 cel codes. all were very minor...
Sparks were misfiring bad- got them replaced with 1step colder.
all hoses/ lines were in perfect condition.
Mike at Ptuning mentioned to clean the MAF sensor... a dirty/faulty MAF sensor goes in safe mode- causes the computer to dump immense amounts of fuel.
He also mentioned to not use any oil- based air filters as they may foul the MAF sensor.
so after everything, we did a test drive-> First 2 gears= complete loss of traction! thats what was missing.
she's running very very good. (knock on wood)
if anything happens, I'll just go back and get a leak- down test...
If anything, do a compression test before a leak-down test.
Compression test firsts tells you if you DO have a loss of compression. The leak-down test tells you Where that loss of compression is coming from.
Originally Posted by youngflyer
dude i thought ur numbers were much higher!
my no.s are 302hp/ 327tq by dynapack (or dynopac... idk some like that) I dont really care cuz I go by Ptuning's no.
