Turbo Thermodynamics!
Ok so Ive taken a lilttle physics myself
..... but to all you tC geniuses out there I like you guys' opinions.......
QUESTION: What is the most properly sized compressor for the tC to effeciently compress air without putting more heat into the charge than thermo law says it should( I realize this aint gonna happen but close can), while moving the most cubic ft/ min air particles?....
ALSO: The most properly sized Turbine A/R ratio to reduce back pressure while still flowing exhaust gases at enough velocity to drive the turbine and not to small that it will show up as power lose in the upper rev range!
SO: With what numbers can I get a turbo with quick spool, with low restriction on the system exhaust wise and low charge temps.... while making good power for a street turbo....
Compressor blades are dynamic and are small AR at start, once up to a point, the vanes changes angle to create a big bigger biggest AR for big power.
Hence NO lag from dig, NO backpressure up top, LOW charge temps, HUGE torque.
See, problem solved........ only issue is that there is no release of this bad ****** any time soon to the general public
Only one car in production has this honor.... the Porsche 997 Twin Turbo, compliments from BorgWarner.
Damn, I wish I was rich.
Sleepermod
Wow see thats cool.... I really learned somthing.... and yes nebster I do have a turbo(t3 45 trim) and works well for my application.... I just learned alot in the process of Turbocharging my vehicle and I wanted to see if anyone had advice on how to create the above mentioned ideal turbocharger
Diesel would generally top out at 950F hot side but a regular gas driven car starts at 1000F topping out at est. 1800F. Double the heat.
BorgWarner got around the issue for the 997 by using ceramic coated vanes + coatings for hot side compressor as well.
Porsche had the budget to do this
Maybe Garrett or Turbonetics should revisit this area and perhaps acquire the license to produce their own range of VATN turbos using BW/Porsche technology?
They would make good biz sense to them and a new toy for us!
SloTC1
Aug 16, 2018 02:45 PM
CrowJenkins
Oct 9, 2015 10:47 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
