Turbo upgrade information needed.
I am looking for infromation on the turbo that is use in the dezod s1 turbo kit.
What brand, size, trims, links to the turbo.
Also turbos will fit the kit as a bolt on replacement.
Thank you.
Thank you.
I have a Dezod S1, although I bought the kit used a few years ago. It is a genuine Garrett, T3/T4E. I can't remember exactly, but I want to say it's a 57 trim. It is a journal bearing turbo without water cooling. I also believe the downpipe is a 5 bolt.
You should be able to confirm some of this in the install manual found here:
Tech Notes
Hope that helps.
Tech Notes
Hope that helps.
Thank you for the information.
I got the same from some facebook post.
I thought i reply a while back to this post but guess it didnt post.
And the install guide dosent say the size, that was the first thing i check
Yea, unfortunately they don't say it. Their website does say Tubonetics, but that was a long time ago. From my understanding, Dezod moved away from Turbonetics due to reliability issues at that time. Not sure if they switched back or not, but I trust Garrett over most other manufacturers when it comes to reliability. The T3/T4E is very old school, but it's also a workhorse.
So I found the post from the original owner of my kit (I bought it from the guy he sold it to, lol). It can be found here: https://www.scionlife.com/forums/ppc...t-sale-226257/
Looks like it matched up with my post. Still don't know the turbine or compressor A/R however.
Yea i was upgrading my custom kit. (Cast manifold, t3 45 trim, 2.25 dp)
And got a t3/t4 t04e 63 from a friend. That turbo was way to big and didnt line up to the dezod manifold and downpipe i brought.
So trying to find out which turbo the kit was model after.
Facebook people gave this number t3/t4 c54 57 std0 82. Turbonetics
So seem like a 57 trim.
Got one of those and installed it a few days ago. Just finish up tuning it.
It spools slower then the 45 trim i had, but this one kerps going to redline. So worth the upgrade to me.
No im in dallas, about 400miles away from huston where its flooded.
This happens all the time that place is under tbe water level and close to the sea so it floods.
The most that happen here was a little rain.
And thanx
And thanx
