Turbo vacuum line install help
Old Jan 31, 2008 | 01:22 AM
borderguy881's Avatar
Default Turbo vacuum line install help
hey guys im just finishing up my stage 0 turbo and the only thing thats left is to run my vac lines from bov and wastegate. ive done my research and ive seen that im supposed to T into the main vac line that is near the throttle body. Could anyone post sum pics of exactly what line to T into becuase i dont want to get this wrong. Is it the line that the green cap evap thing is?
Old Jan 31, 2008 | 05:49 AM
aen's Avatar
aen
just wait for mr meaty. he will come with pictures upon pictures for you.
Old Jan 31, 2008 | 12:34 PM
aight ill try and pm him
Old Feb 16, 2008 | 01:27 AM
powerhouse7256's Avatar
im having the same problem can somebody pm me or post something to help me out! thanks
Old Feb 21, 2008 | 07:26 AM
Mr_Meaty's Avatar
Damn...I'm late as hell to this thread, aren't I?
the one everyone taps their BOV is this one with the yellow circle on the right, where the intake goes into teh throttle body:
the yellow circle on the left is where you can tap a vac block into.
Here is another shot of the other end of the thick break line where you could tap a vac block into:
I highly recommend getting a vac block instead of tee-ing everything off...It's much cleaner, easier, and it looks good, as you can see in the first pic.
Old Feb 21, 2008 | 07:27 AM
Mr_Meaty's Avatar
I need to have some kind of alarm on here that goes off whenever anyone mentions my name that alerts me to which thread I need to post in!
Old Feb 21, 2008 | 01:52 PM
now did you have to cut that big thick vacuum line, i think its the break booster from what somebody else said? regardless didyou have to cut it ?
Old Feb 21, 2008 | 10:39 PM
Mr_Meaty's Avatar
No...you need to by some additional tubing of the same size. The 2 ends of the brake booster line are connected to a pvc pipe going along the back of the firewall.
You unplug one end and plug that into one end of the vac block, as long as it will reach.
Then you take your new line you bought and plug it into the other end of the vac block. You take the other end of your new line and plug it into the end of the pvc pipe that you disconnected the original break booster line from.
Does that make sense?
Old Jan 16, 2015 | 08:51 PM
MyTCSick's Avatar
Default hey
hey bro am so stuck.... i have like alot of questions.
1. after i tap into the brake booster line to the inlet of the vaccum block, where am i suppose to do with the outliet side of the block? like where do i hook the outlet of the block too and is that was you was talking about when you said i need to buy a new hose?
2. if am using the booster line do i still use the block to bov or throttle body to bov?
3. am running a manual boost controller on an internal wastegate so is it suppose to be block to inlet of contoller then outlet of controller to internal wastegate?
4. emange line and boost gauge just hooks up from the block right..
please help i know this is an old thread.
Old Jan 16, 2015 | 09:11 PM
Ace83's Avatar
Ronin Scion
You might need that extention line to join the other end of that oem vacuum line (brake booster line) to the other side of your vacuum block. You can run your bov vacuum line to one of the ports on your vacuum block to. You can use the vacuum block for the emanage and boost gauge and controller as well.
Old Jan 23, 2015 | 06:57 PM
burgandybomber's Avatar
A vacuum block is basically a big space that vacuum occupies. It allows you to have one splice into a vacuum source and cleanly route any accessories that require a vacuum source.
I have my brake booster line T'd with a T you can get at just about any auto parts store or mega mart. The open end of the T goes to the vac block. Any accessory that needs a vacuum source is then connected to the block and plumbed to the accessory appropriately (somewhere it wont melt or get in the way of something in motion and I like to zip tie the lines so I know they are safe). There really isn't an "inlet" or "outlet". Where ever you source the vacuum from is now your inlet and all the other ports become outlets.
Old Jan 26, 2015 | 03:28 AM
SloTC1's Avatar
Vacuum block makes it cleaner and more efficient. Especially if you may experience vacuum leaks at some point. Instead of having to check all the T's you can check the block and the lines right off of it
Brammi
Nov 13, 2016 03:46 AM
my06tc
Jun 25, 2015 12:18 AM
Frustratez
Feb 26, 2015 04:03 PM
darkshadowofxdeath
Feb 11, 2015 05:38 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
