Turbos From dezod
No they are not. I had to clock mine and they are VERY simple to do. There are bolts on both the compressor side and the exhaust side of the turbo that you losen, then rotate the turbo, then retighten.
Joe sent me a very good picture to describe how to do it, just checked my savebox and i don't have it anymore. JOE, post it up man!
Originally Posted by etsnet
This may be a dumb question but what do you mean by clocked? I haven't heard that term in my short time as a booster.
Originally Posted by Crippie
what is the advantage of this? better contact surface? making sure the inlets/outlets are perfectly lined up? second time i hear about clocking
Yes every turbo from every manufacturer needs to be clocked. It is very simple, and consists of lossening the bolts on the bacl of the comp housing and turbine housing to rotate the assembly as needed, then retightening.
Ok ya it wasn't hard at all the clock the turbo. Is it really necessary to have a diagram, because it seems like as long as you have a good pic of the turbo in the bay correctly you can base the clocking off of the that. Everything is ready to go except tomorrow I'm going to need to swap the injectors, wire my gauges, and plug up the emanage...Then I'll finally be able to fire it up...maybe. My primary o2 was crossthreaded horribly and took almost 45 minutes to get out. the threads are mangled and I don't know if I'll be able to re thread the sensor. Has anyone had good luck with re threading that sensor? I don't think it's a good idea at all to run without my o2. Finally, does my wastegate know to push only 8.5 pounds, since I don't have a manual boost controller? Is it pre set?
Hope this helps
We do sell the springs seperately though so you can run almost any boost level you want.
Note- I replied to the PMs I received for the "clocking" picture.
If anyone else has questions let me know.
Your tial wastegate will come with an 8lb spring already in the cap ready for it to just be bolted to the manifold and dp. Check your tial box, it should say .6 bar on it.
Scionxa180
Sep 24, 2015 03:51 AM
my06tc
Jun 25, 2015 12:18 AM
