turning up the boost
Old Jul 21, 2010 | 03:29 PM
dudemandudetc's Avatar
Default turning up the boost
OK so as of right now im running at 7psi with a zpi kit with a intercooler and emange blue im making about 253whp and 279 with a cutout i plan on upgrading to aem fic and buying a 255 walbro fuel pump i have 440cc injectors i want run 9lbs of boost but dont know if i should buy a boost controller or if i should just get a bigger wastegate spring i feel a little ifffy about a boost controller just nervous about boost spikes and also dont know what is good for a tc and i also plan on buying a vaccum block what do u guys recommand i did all trhe searching i could try find and couldnt find nothing so needed to post a thread this is my daily driver during the spring summer and some what fall till first snow fall falls
Old Jul 21, 2010 | 04:00 PM
bdis3's Avatar
1. Punctuation.
2. If your not planning on going more than 9psi, just get the spring
3. Dezod Vac block
4. Search better
Old Jul 21, 2010 | 04:33 PM
gwopsta's Avatar
get the spring, cheaper and safer
Old Jul 21, 2010 | 05:22 PM
mattTc's Avatar
Originally Posted by bdis3
1. Punctuation.
3. Dezod Vac block
4. Search better
I lol'd at #1
Old Jul 21, 2010 | 06:55 PM
speedy000's Avatar
the spring is cheaper but there is several threads already bout people running 8-9psi springs and only hitting 6-7psi i say get the boost controller. if u end up ordering a 9psi spring and u only hit 7 then u just wasted 25$
Old Jul 21, 2010 | 08:32 PM
gingles's Avatar
then order a 10 or 12 psi spring......10 or 12 psi is fine on stock block
Old Jul 21, 2010 | 09:41 PM
skinnayyy's Avatar
Team Scionara
10 or 12 psi will be wayyy too much for 440cc injectors though wouldn't it? i have 630cc's and am ~70% on 10 psi.
Old Jul 21, 2010 | 10:35 PM
gingles's Avatar
440s with a walbro on a 16g would probably be fine.
Old Jul 22, 2010 | 12:38 AM
deathbyc4's Avatar
440cc is fine if you have a 1:1 FPR.
Old Jul 22, 2010 | 03:19 AM
tcscion06's Avatar
Default turning up boost
I got a zpi stage 1 kit and im thinking of changing the wastegate spring to 13lbs, is it safe to run 13 psi on the stock motor?
Old Jul 22, 2010 | 03:23 AM
gingles's Avatar
search...but yes you can.
Old Jul 22, 2010 | 04:02 AM
draxcaliber's Avatar
i'm using an 80 dollar turbo xs manual boost controller and running 14 psi. don't know what seems so dangerous about this boost controller. i just got it cuz i wanted to increase boost until i met my power goals.
Old Jul 22, 2010 | 04:51 AM
ok im thinking spring would be a great but what brand and what would the spring i would have to run for 9psi be
Old Jul 22, 2010 | 08:54 AM
bdis3's Avatar
tialsport.com
Old Jul 28, 2010 | 11:34 PM
line em up's Avatar
what are you raising it to
Old Jul 29, 2010 | 01:35 PM
maherdan82's Avatar
I would say spring would be safest. I have a 8lb spring in my Turbonetics evolution WG and can dial it up to 10lb's no prob. with the spring tension adjustment. Don't even know what a boost spike is.....never had one!
k1114
43
Mar 1, 2023 03:08 AM
jctc06
Apr 16, 2015 12:11 AM
clickclickw00t
Feb 18, 2015 08:57 PM
setpol
Feb 17, 2015 11:33 PM
spawnconnery
Dec 18, 2014 08:38 PM
