Vaccum Lines
Old Sep 27, 2006 | 11:22 AM
Rasta's Avatar
Default Vaccum Lines
I just purchased a vacuum block for my TC what do you guys think is the best main vacuum source for the Block?
Old Sep 27, 2006 | 12:46 PM
zer0's Avatar
Tee off the brakebooster. And/or Tap your throttle body.
Setup on a Honda via Brake Booster..
Old Sep 27, 2006 | 04:43 PM
Rasta's Avatar
Thanks tapping the throttle body might me a pain in the a-- you know. I gues teeing the booster is a real good vaccum.
Old Sep 27, 2006 | 06:48 PM
Prototype_xB's Avatar
you should tap in here:
(** Taken from Kaeon's thread---> https://www.scionlife.com/forums/vie...=67002&start=0 **)
Remove this to access your vac line. Its under this plug.
Remove the line from the bottom of the plug
Place the T Fitting in the vac line and cut about an inche off the vac tube off
Flip the T around and plug it into the vac line you just cut.
Old Sep 27, 2006 | 07:53 PM
Joe_Dezod's Avatar
I did notice the boost gauge being more steady, and having a better idle, when I had the TB tapped. Keep that in mind. But yes it is much harder to do.
Old Sep 27, 2006 | 07:58 PM
WeDriveScions's Avatar
I tapped close to the TB off the line, which isn't that hard to get to, but works well for me and can't be that much different than the TB itself...
Old Sep 27, 2006 | 09:22 PM
CervezA's Avatar
have mine tapped closer to the tb as well and no problems here.
Old Sep 28, 2006 | 02:30 PM
Rasta's Avatar
Where did you tap the TB can you put a pic if it is not too much trouble I would appreciate it.
Old Sep 28, 2006 | 02:32 PM
tC4italy's Avatar
I thought this was "why are there lines after I vacumm my interior" thread awww man I need coffe
Old Sep 28, 2006 | 03:20 PM
Rasta's Avatar
Do you know the actual sizes of the lines I might get some silicone ones?
Old Sep 28, 2006 | 09:10 PM
Streeter's Avatar
If you can find a good price on some silicon vaccum hose please PM me. (Red specifically.)
Old Sep 29, 2006 | 03:41 AM
soros151's Avatar
I replace the vacuum line from the photos with silicone ones, but all they gave me where a CEL. I have to do it again to see what was the problem.
gqdabien
Oct 8, 2015 05:36 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
edwinisdumb15
Regional - Pacific South
Sep 18, 2015 10:48 PM
prescottn
Sep 13, 2015 09:04 PM
gottoaster
Sep 6, 2015 07:17 PM
