Weapon R Supercharger Short Ram Intake?
Old Nov 8, 2007 | 07:30 AM
xunst0pablex's Avatar
Default Weapon R Supercharger Short Ram Intake?
It's a Short Ram..Anyone have it?
Any problems with the S/C?
Old Nov 8, 2007 | 11:18 AM
JBodygoneTRD's Avatar
it will probably lean out, unless you tune.
Old Nov 8, 2007 | 08:44 PM
anymore opinions?
Old Nov 8, 2007 | 11:41 PM
cee_dub2003's Avatar
It will not lean out. We made the intake work with the TRD Tune.
Old Nov 9, 2007 | 01:34 AM
i stand corrected
Old Aug 17, 2008 | 08:46 PM
yellowxboy's Avatar
theres a difference between the weapon-r secret intake vs the weapon-r supercharger intake?
i tried looking for a picture comparison but i couldn't find any.
Old Aug 17, 2008 | 08:50 PM
yellowxboy's Avatar
never mind. FYI for anybody else that's curious:
vs
Old Aug 20, 2008 | 03:40 PM
Avodka14's Avatar
It will lean out unless you get a tune and especially if you are running a smaller SC pulley. The TRD map sucks anyways and I can't wait to get mine retuned.
Old Aug 20, 2008 | 07:22 PM
yellowxboy's Avatar
w/o a gauge, how can you tell if you're going to 'lean out' ?
Old Aug 20, 2008 | 08:31 PM
jetlounge's Avatar
because this is the internets!
and any old myth/wives tale/opinion/"i heard it from a guy who heard it from a guy" is the TRUTH on the internets!
Old Mar 20, 2009 | 04:53 PM
Avodka14's Avatar
Alright guys, I just installed my Weapon R SC intake with my 9.5 NST pulley. I have an 05 tC and everything runs just fine! I believe the ECU has adjusted a little in the couple of days since the install. I am putting out black smoke (indicating rich fuel mixture) at WOT.
Old Apr 13, 2009 | 04:31 AM
jedred1's Avatar
Are you still having this black smoke problem? I'm considering the same intake. Did you note a power gain? I'm also looking into the 9.5 NST pulley as well but one thing at a time. Did you end up tuning?
Old Jul 12, 2009 | 09:13 PM
SoulXquisite's Avatar
-what's the cheapest site that sells this intake?
Old Nov 26, 2009 | 12:49 AM
CLT-tc's Avatar
$199 is the cheapest i have found
http://www.erzperformance.com/Produc...2D101&CartID=2
so does anyone know how this will effect the s/c with the 9.5 psi pulley, will it run lean, any additional hp?
Old Nov 26, 2009 | 06:09 AM
gwtc's Avatar
I have a friend who has an 07 tC with the TRD SC and he installed that intake, he was running fine for a couple of days, but then all of a sudden he was only getting 2psi, we tried all kinds of fixes, changing the fasteners for better ones, adding a better BPV, those things help a bit, got it back up to 5psi, but sometimes it would dip back down to 3, so he took it off and put the stock air box in and drove normal for a day or two and now, 7psi all the time, just like before he installed the intake so if I was going to install that intake I would wait til I got re-tune.
Old Nov 26, 2009 | 12:44 PM
b52hDUNN's Avatar
There's no way a intake could affect boost pressure like that. Seems like they have a bad bpv, that is opening when it shouldn't be. If anything the boost pressure should be a little faster since the supercharger is getting a larger volume of air to compress.
Been running a custom built intake on my supercharger for 5 months and no problems.
Old Nov 26, 2009 | 05:51 PM
gwtc's Avatar
Like I said we tried everything and it was not the BPV, plus were talking about the weapon R intake, not a custome made one like yours, glad yours is working for you thou.
Old Nov 27, 2009 | 07:23 AM
CLT-tc's Avatar
nice set up b52...
who else runs a custome or brand intake with their s/c tc? should i get a drop in filter or a short ram? can it lean you out with my 9.5 psi pulley? please help
Old Nov 27, 2009 | 01:55 PM
b52hDUNN's Avatar
thanks, there is a few others out there. I also have the 9.5lb pulley and it works great with my setup.
Old Nov 27, 2009 | 06:10 PM
streettimetc's Avatar
iv been running both pulley and custom intake for 9 months and 20,000miles with no problem
