Wheel Spin
Old Mar 13, 2011 | 12:14 AM
Rasta's Avatar
Default Wheel Spin
Man you guys that are making big power, What do you do about wheel spin? Its a huge problem. My car just spins tires that it man...anybody?
Old Mar 13, 2011 | 12:45 AM
brett561tc's Avatar
dont shift till the rpms drop then come back up again.
Old Mar 13, 2011 | 09:15 AM
matt's Avatar
i watch the speedo. when it hits 35, i shift into 2nd.
Old Mar 13, 2011 | 12:05 PM
Rasta's Avatar
I dont even have 2md or 3rd gear I can only get half way on the gas...sux!
Old Mar 13, 2011 | 01:23 PM
rhythmnsmoke's Avatar
Music City Scions
Race above Peak Torque RPM as well as beefy wheel/tire setup.
Old Mar 13, 2011 | 01:31 PM
06tcdude's Avatar
get the polyeurathane bushings. They are cheap and they work wonders.
Old Mar 13, 2011 | 01:32 PM
Music City Scions
He already has solid mounts.
Other solution also....run a boost by gear setup.
Old Mar 13, 2011 | 03:56 PM
trd07tc's Avatar
buy slicks
Old Mar 13, 2011 | 04:36 PM
mmmpshh's Avatar
im about to test out these nitto nt01's.... they feel pretty damn sticky
Old Mar 13, 2011 | 07:25 PM
m6ar2cel6oTC's Avatar
boost by gear, drag radials, mounts, lsd and your good. and if your going to the track full blown big ol slicks only way to go
Old Mar 13, 2011 | 07:53 PM
Rasta's Avatar
I have them 235's my car is wanted for murdering them.
Old Mar 13, 2011 | 07:54 PM
Rasta's Avatar
I have a LSD, Im going to have to boost by gear I want to be able to hook on the street. I going to buy some 19's for this car. Get as wide as i can, I figure the 19's might gear it up a little.
Old Mar 13, 2011 | 07:55 PM
Rasta's Avatar
I am going to try and put some lead packs in the front somewhere
Old Mar 13, 2011 | 08:13 PM
brett561tc's Avatar
you could try having your front wheels aligned toe out slightly, and make the rear suspension as stiff as possible. nothing you do will compare to racing slicks though.
Old Mar 14, 2011 | 01:30 AM
mmmpshh's Avatar
are you serious, damn. I had high hipes for these tires. Are you going from a dig? low roll high roll?
Old Mar 14, 2011 | 02:27 AM
Syldrin's Avatar
i stand by my statment in our last tire post. dunlops
Old Mar 14, 2011 | 02:55 AM
bro you dont need 19's. if your serious about get some 18X9.5 and throw on some 275/35/18 and some nt01 and your good as gold. i have 18X9.5 and some 255/35/18 and i spin 1-2 if its from a dig and if its from a 40 roll i just spin the top of 3rd gear. but if you do go with 275/35/18 you will need to roll your fenders and if you wanna be real dropped you will have to pull them.let me know i got a hook up to roll fenders and pull them if needed. i also have a place that sells tires around 50% thread life for like 27 bucks and imean good tires like bridgestone re050 or michelin ps2 on some continental contact 3's let me know. text me
Old Mar 14, 2011 | 12:45 PM
Rasta's Avatar
I dont have a 1st and 2nd gear brotha..If Im halfway on the gas in 3rd and it goes into boost about 4500 the tires cut loose.
Old Mar 14, 2011 | 12:46 PM
Rasta's Avatar
Cool brotha thanks for the head up. That might be my route.
Old Mar 14, 2011 | 01:55 PM
paul_dezod's Avatar
Scionetics
KAD
DING!
Ding!
Ding!
Get wider rubber, stiffer suspension, poly mounts and a REAL full locking LSD. Quaife is fine for low power, but OS is where BIG power shines
