Why is the TRD SC for the tc so finicky about installation?
Hi everyone,
Can someone summarize why the TRD tc SC installation is so finicky? Is it because it's just a really bad bolt-on design?
I see threads here all the time about busted seals, oil leaking from every orifice and ruining the cats, bearings being rubbed down into nothingness, brackets breaking, engines exploding, etc. Can someone summarize it for me? (maybe synthetic motor oil actually disolves TRD tc SC O-rings. Heh.)
If you have to feed your car a qt everytime you gas up....that's not right. Even if it is a supercharger (right?) I know you have to check the filters, and the belts on the TRD / Vortech SC but what is it about the install / design that is so $*((&@&(#$($ hard.
I find that a lot of the time that people install something that requires proper alignment (pumps, anything with a sealed shaft, etc) they do it improperly and something goes wrong.
I dont know what exactly is involved with the SC setup, since I have never seen one close up, but install error is always one thing to look for.
Maybe its just because this is the internet and small issues get blown out of proportion. This topic has been tossed around alot. The real issue is that a person who has a good experience will tell 2-3 people and a person with a bad experience will tell 11. That's a statistically proven fact. There are enough people on here that have never had a problem and when a new thread pops up about have you ever had a problem with your supercharger some of us chime in. While the ones who have had a problem always chime in. You keep reading about issues because thats all anyone posts about. How many threads have you seen just randomly started about "Wow my supercharger works great I've never had a problem in 10k miles." People don't start threads like that. However since I brought it up I have 10k with no issues, With a header, custom intake, nst pully set, bpv, header wrap, vented catch can, and its dealer installed. Had most of this since day one and still no issues. I have a friend with almost 20k on his now with similar mods with no issues aswell.
^^^Great summation. Posts on here are not put up showing great things, becuase we EXPECT them to work. This makes it seem like everyone is having problems, which is not the case at all. As the old saying goes, "the squeeky wheels always gets the oil".
the other problem is just reality..most of your local toyota service stations are used to doing oil changes, recall service and putting wiper fluid in your reservoir.
they do not install turbo's or s/c's or do 8 hour builds every day.
so imagine giving someone who is good with a wrench on a car a 50 page document on an install that needs to be precise, a box of parts and say "go do!" that's like giving the same thing to you or me...only you or me..we might ask buddy for assistance, we might go on the net for additional info...we take our time...
trd does not apparently have a robust training program for the service techs..THAT is the real problem.
what they need to create is a few regional centers of excellence..so you get maybe 'TRD authorized' centers. They send the guys to training, they know all of the foibles, and they are the only ones you go to for real performance part upgrade. Leave the oil changes to your local yokal.
Everything has a proper way to be installed and a million improper way to be installed. If you follow the instructions like you are supposed to then everything works fine. The problem is (as much as I hate to admit it) there are some techs that have the "I've been working on cars forever" attitude and "I know what I'm doing" and don't really follow the instructions to the T. If you don't tighten the bracket down in the proper sequence like in the instructions it's going to cause issues.
trd sparks is right.. i have my sc for around 6 months with around 5.5k on it now and no problems here runnin with nst pully and mmw header and draxas exhaust.. and i do get on it from time to time not alot most just drive to work and home. and weekend use.. and havnt had any bracket broken or any problems.. when i did do the installed thanks to trdsparks letting me know that i have an older ver.. of the install.. but he told me what i need to do.. and also i had the toyota main repair man.. and it did tell you to align and set everything b4 tighten.. soo.. i have no problems at all
Team No Limitz
I received my monthly scion says newsletter and it shows that you can order parts indiviually now for the 05-06 supercharger...the blower itself is listed as around $1600 MSRP
Injectors were like $500 for the set
Here's a list if you guys need it.
Name Replacement Part Part Number
TRD, Torque Biasing Differential, 5 spd PTR39-21070
Brakes, TRD, Pads, Front Set PTR01-21050-34
Clutches, TRD, Assembly PTR15-21051-60
Cold Air Intake, TRD, tC PTR03-21060
Engine Cover, TRD, Carbon Fiber, Supercharged PTR34-21070
Exhaust, TRD, Sport Muffler PT400-52840
Filters, TRD, Kit, Cleaning PTR05-00000-CL
Filters, TRD, Air, 2.4L I4 PTR05-12030-10
Filters, TRD, Oil PTR14-00000-06
Oil Caps, TRD, Screw-on, Japan PTR04-12108-02
Oil Caps, TRD, Billet Aluminum, Screw-on Style PTR35-00070
Oil Caps, TRD, Billet Oil Filler Cap Gasket Replacement Part PTS26-52050-GR
Quickshifter, TRD PTR04-21051-40
Radiator Caps, TRD PTR04-21050-01
Service Parts, TRD, Supercharger Compressor Housing Bracket Replacement Part PTR01-21054
Service Parts, TRD, Emblem, "Supercharged", Plastic Blister Type PTR01-3500E-MB
Service Parts, TRD, Emblem, Small Rectangular, Plastic Bubble Type PTR01-3500T-RD
Service Parts, TRD 2.4AZ S/C, Cold Plug Replacement Part PTR24-21050-00
Service Parts, TRD, Spark Plug PTR24-21055-01
Service Parts, TRD 2.4AZ S/C, Rear Bracket Replacement Part PTR25-21060
Service Parts, TRD 2AZ S/C, Drive Belt Replacement Part PTR30-21060
Service Parts, TRD 2.4AZ S/C, Wire Harness Relocation Kit Replacement Part PTR41-21050
Service Parts, TRD 2.4AZ S/C, Bracket Kit, AC Hose / Wire Harness Relocation Replacement Part PTR41-21051
Service Parts, TRD 2.4AZ S/C, Oil Feed Line T-Adaptor, AN to NPT Fitting, ByPass Valve Tee Replacement Part PTR41-21052
Service Parts, TRD 2.4AZ S/C, Idler Bracket Bolt w / Oil Return Line Hardware Kit Replacement Part PTR41-21053
Service Parts, TRD 2.4AZ S/C, Valve, Bypass Replacement Part PTR41-21054
Service Parts, TRD 2.4AZ S/C, Air Box Assy Kit Lower w/inlet Adaptor Replacement Part PTR41-21055
Service Parts, TRD 2.4AZ S/C, ECU Remap Module Replacement Part PTR41-21056
Service Parts, TRD 2.4AZ S/C, Crank Position Sensor Wire Ext. Assy. Replacement Part PTR41-21057
Service Parts, TRD 2.4AZ S/C, VSV Rubber Mount, VSV Hose & Bypass Valve Hose Kit Replacement Part PTR41-21058
Service Parts, TRD 2.4AZ S/C, Hose, Oil Feed Assy Replacement Part PTR41-21059
Service Parts, TRD 2.4AZ S/C, Rear Mounting Bracket, assembly, Aluminum Cast Replacement Part PTR41-21060
Service Parts, TRD 2.4AZ S/C, Crankshaft Bolt Replacement Part PTR41-21061
Service Parts, TRD 2.4AZ S/C, Idler Pulley Replacement Part PTR41-21062
Service Parts, TRD 2.4AZ S/C, Driven Pulley w/Hardware Kit Replacement Part PTR41-21063
Service Parts, TRD 2.4AZ S/C, Air Box Rubber Mounts & Sleeves Replacement Part PTR41-21064
Service Parts, TRD 2.4AZ S/C, Driven Pulley Shim Asst. Kit Replacement Part PTR41-21065
Service Parts, TRD 2.4AZ S/C, Clamp Kit Replacement Part PTR41-21066
Service Parts, TRD 2.4AZ S/C, Idler Pulley Hardware Kit Replacement Part PTR41-21067
Service Parts, TRD 2.4AZ S/C, Inlet Cover Replacement Part PTR41-21068
Service Parts, TRD 2.4AZ S/C, O-Ring, Supercharged tC Replacement Part PTR41-21069
Service Parts, TRD 2.4AZ S/C, Oil Pan w/ Return Tube Replacement Part PTR41-21160
Service Parts, TRD 2.4AZ S/C, Thermostat, 70C / 160F Replacement Part PTR41-21161
Service Parts, TRD 2.4AZ S/C, Formed Fuel Line Assembly Replacement Part PTR41-21162
Service Parts, TRD 2.4AZ S/C, Fuel Injectors, High-Flow Replacement Part PTR41-21163
Service Parts, TRD 2.4AZ S/C, Gasket, HC Trap Holder, Buna Replacement Part PTR41-21164
Service Parts, TRD 2.4AZ, Supercharger Main Assy. Replacement Part PTR41-21165
Service Parts, TRD 2.4AZ S/C, Insulator, Exhaust: Stamped Replacement Part PTR41-21166
Service Parts, TRD 2.4AZ S/C, Hose Kit: Inlet/Outlet/Bypass Replacement Part PTR41-21167
Service Parts, TRD 2.4AZ S/C, Hose, Water Return Replacement Part PTR41-21168
Service Parts, TRD 2.4AZ S/C, Oil Return Hard Line Assy. Replacement Part PTR41-21169
Service Parts, TRD 2.4AZ S/C, Rear Bracket & Inlet Cover Hardware Replacement Part PTR41-21170
Shift *****, TRD, Leather, Large PTR04-00000-05
Shift *****, TRD, Ball, Manual Transmission PTR04-00000-06
Shift *****, TRD, Brushed Alum, 5-Speed PTR34-52070
Shift Light, TRD, Recording Kit PTR01-21065
Supercharger, TRD, 2.4L PTR01-21050-90
Supercharger, TRD, A/T Fit Kit PTR01-21051
Suspension, TRD, Strut Tie Bar PTR02-21060
Suspension, TRD, Shock Absorbers, Set PTR04-21051-60
Suspension, TRD, Lowering Springs, Set PTR11-21050-35
Suspension, TRD, Sway Bar, Rear PTR11-21051-10
Suspension, TRD, Coil-Over PTR11-21070
Suspension, Lowering Springs, Red PTR11-21070-03
Wheels, Cap, TRD Replacement Part PTR18-12003-05
Wheels, 5 Spoke Silver PTR18-21070
Wheels, TRD Hex Head Lugnut Replacement Part PTR18-21071
Wheels, TRD, 18" x 7.5", 5-Spoke Silver PTR18-33973-01
It’s a mechanical devise, you’re always going to have a few fail somewhere. Somehow I found a way to burn up 2: one with a seal the other with a bearing….. took out the engine. What are the odds, although they were both installed at the same place by the same person…..
Originally Posted by hawgs74
Mabe it has to do with the generic design that they just adapt to fit different apps. Guys are blowin their engines on dealer installs with no mods. Thats just scary!
Installation is everything, I never had one problem with my supercharger and I beat the living heck out my car racing over and over (and I did take good care of course). You all have good point about the way the SC has been, but it does not rule out the kit being unreliable nor fun.
I have the lower and upper tubes that connect to the engine and supercharger, but the airbox assembly was missing from my kit (i bought it off craigslist used for 1500)
thanks for the help!
