will this work ok with a TRD supercharger??? plz help
Old Apr 22, 2008 | 04:16 AM
xCxHxRxIxSx's Avatar
Default will this work ok with a TRD supercharger??? plz help
ok it says do not use with turbo or supercharger on nos . but trd supercharger runs off stock so wouldnt it be ok . it has a 40% tq increase over stock clutch clamp force.
so this clutch should be ok right? below is specs. it is a competition clutch
Stage 1 - Gravity Series 2400 Clutch Kit
The economical solution for moderately modified cars or simply aggressive individuals with stock power. Offers 40-50% of torque capacity and maintains stock pedal feel.
DO NOT use with added forced induction such as turbo, supercharger, or NOS systems.
The 2400 Series kit includes a Competition Clutch pressure plate, a 6 pad Carbotic high-torque performance disc assembly, all applicable bearings and the appropriate alignment tool.
Old Apr 22, 2008 | 04:20 AM
draxcaliber's Avatar
stock clutch is fine with the supercharger, unless you wail on it.
but the stock clutch will be fine and last for a while before it starts slipping.
Old Apr 22, 2008 | 04:29 AM
so this stage one should work fine even though it says dont use with added forced induction
Old Apr 22, 2008 | 04:31 AM
scionkidd's Avatar
the reason why it says not to use it with the superchargers is b/c some s/c give you 50-150 added hp over stock... the stock clutch is fine for the s/c!
if you do need a new one cuz ur existing one is slipping (rpm goes up but speed remains same) get clutchmasters stage one, or even stage two.
Old Apr 22, 2008 | 04:40 AM
thsnks for the fast input . the reason why i asked about this stage one is because im gettin a package deal for this and competition clutches light weight flywheel
Old Apr 22, 2008 | 04:48 AM
scionkidd's Avatar
yea if ur not runnin anything serious, then stage 1 is all you need!
no problem
Old Apr 22, 2008 | 05:08 AM
kikcaffine's Avatar
Which flywheel are you getting?
Old Apr 22, 2008 | 05:24 AM
competition clutch light weight forged steel flywheel . not the ultra light cuz i want it to be street able with alot of stop and go
Solowcal_tc1
14
Feb 27, 2024 06:23 PM
Halo19boy
Jan 27, 2015 10:19 PM
JPuehl
Jan 10, 2015 01:01 AM
757_BRDFLY
Jan 9, 2015 12:29 PM
TheTripleC
Jan 4, 2015 06:46 PM
