ZPI Stage 0 E-manage map
You'd probably be better off using the GReddy map on our site.
http://www.dezod.com/tech_notes.cfm
DL it here^^
DL it here^^
will the base map from greddy run okay? and the other question i have forgive my newbieness how do i put the map from the computer onto the blue box do i just hook up my cable. Do i need the boost presure sensor with my blue box or is the box sufficient with the greddy tune? And finally sry to thred jak how do i get the blue box to talk to my dang car its wired right but its like its locking me out its upgraded to the newest thing (1.49) or wutever but all my menu bars are "greyed out" plz help thnx and sry for the jack
anyway, you'll need a harness to wire it to the car, and you only need a pressure sensor if you want to tune off boost instead of off the MAF sensor. and to get it to talk to your car, you need to connect by either splicing the wires, or using a PnP harness to plug it into your car via the port in the glovebox.
anyway, sounds like you don't know what your doing, take it to get tuned professionally because you can do some serious harm with a bad tune.
i spliced and i quadrouple checked ive got a pretty good idea on wut i need to do im just new to the whole blue box tunning thing but i got the whole idea of boost and lean rich and wut not just not. how do i get the dang thing to unlock???
Is the greddy basemap on dezod's site good only for the greddy kit or stage 0s? the file name has a number 440, does it mean its for a kit with 440 cc injectors? Im gonna be running TT stage I wuz wondering if there's any map that would be good enough to use while waiting to be tuned. I Opened the greddy basemap and it only has the injector map, I have another map (zpi supposedly) and it has 3 maps (Air flow adjustment map, injector map and the Ignition timing adjustment map) but the greddy map looks more loaded with numbers though. So the question, which one is better with a stage I TT kit?
What do you mean locked you out? to load map to the box, 1st you have to connect the box to your laptop
then open your map, and then press export to main unit.. really i havent tried it but its looks as simple as that (lol newbie too)
yea heard bout that but is the password locked in the box (emanage) itself requiring you to enter password before you can export or view the map used or is the password placed in the map file not allowing you to load the map to the unit without it
vi3tb0i09
Sep 23, 2015 08:32 PM
