0ga fit with no prob?
Well I need to upgrade to 0ga
basically a short question
will 0 ga fit in the door sill passage way?
or will I have to take the drivers seat out and run it that way?
thanks for the help
thanks for the help
It fits through the fire wall but it is a nightmare to get through........my wife had to push it and I had to grab it with hemostats from under the dash to get it........
It will fit in the channel withthe other wires along the door......but just barely.......
I decided to remove the gas door opener and run it under that and throughthe brace channel along the door edge on the floor itself.........there is liek a perfect spot under the carpet.....you just have to take out a small piece of the floor padding under the gas door lever to fit the wire under the lever when it goes back in........10 mm bolt.
I did not have to remove seats to get under the carpet either but it would of been easier......hope that helps.
wiltonhall
Jun 23, 2025 10:09 PM
SpaceCaptain
May 11, 2015 06:24 PM
