8" components in front doors of tC (Updated w/pics)
Originally Posted by 1nicescion
I think it can be a good solution for midbass, but only when it's midbass frequencies only, such as a bandpass signal from 50Hz to 200Hz, with a sub handling the lower freq's and midranges-tweeters (located elsewhere, such as the kick-panels) covering everything above the MB's low-pass point
example - your sub plays at 200 down tune the mids at 180 up this way you have no gaps in the frequency response. Using an rta will show the gaps in the freq that you need to fill and adjust accordingly via crossover gains. if passive crossovers are used, then use the closest setting to the frequency response of the given speaker.
Generally the subwoofer's should only play from 80hz and down. Why? Because if they are allowed to play higher, our ears will easily localize them behind us. An 80hz sound wave is ~6" long - similar to the distance between our ears. Frequencies lower than this (and thus longer in length) become increasingly difficult to locate because we haven't heard the entire wave. In my car, I'm using a 31hz low pass for my subwoofers, and 40hz high pass on my midbass. The tC has a ton of cabin gain in this region, and thus "fills in" the gap naturally. I don't suggest anyone use these ultra low crossover points unless you've got some killer midbass drivers, and/or don't jam on the system. However, there's a HUGE difference between 40hz and 80hz. The speaker will move 4X as much for the same output at 40hz vs 80hz! You can see how quickly you'll run out of mechanical excursion. I suggest something in the middle for most listening - say ~60hz @ 24dB/oct. Do NOT mix and match crossover slopes! This will result in several phase issues. Generally speaking - in car audio, steeper slopes (24dB/oct) are better, and use the same frequencies on each side of the xover. For example: 80hz low pass for the sub, and 80hz highpass for the midbass.
Let's remember that IDEALLY we want our stereo's to reproduce music as if we were at the venue it was recorded at. Visualize an acoustic performance - say at a coffee shop where the band members are setup left to right against a wall, with the lead singer centered. Our table is 10 feet back, and left of center. Of course, NONE of the musicians or their instruments are behind us, making 100% of the musical energy coming from in front of us.
Our car's should be able to reproduce this exact sonic experience. One of the ways we can do this is to properly set the crossover points. The lower the crossover frequency we use for the midbass, the more musical energy will be coming from in front of us. Subwoofers should only add to the impact in the lowest octaves. I would suggest using a high crossover point from the midbass the tweeters...something ~2KHz+. This will force most of the critical midrange to come from ONE pair of speakers, and will help maintain sound stage focus and thus image placement and stability will be much better.
Actually I do have a Question for you. Do I set my 8" components to 80hz highpass? What about my 5 1/4 components that I have in the rear location, set them to 250hz highpass?
My system consist of :
Pioneer D-3
Memphis M/class 50x4 @ 4ohms
Memphis M/class 500d @ 2ohms
Memphis 8" components
Memphis 5 1/4 components
Pioneer Shallow Mount 10" sub
Pioneer D-3
Originally Posted by nodsetse
Originally Posted by Adidude
I will be pairing mine with a 4" mid and a 1" tweeter in kicks.
It's only when people try to use an 8" midbass over too wide of a range when there's an issue, such as when it's required to produce midrange frequencies to match a small tweeter, such that the crossover point is fairly high. This is further compounded by the stock door hole location in the tC, relative to the listening positions.
If anyone really wants an 8" MB in the doors and only a 2-way system (no MR for the range from MB to tweeter), I suggest you look into this setup, or a similar component set from one of the few other companies that offer them.
Pioneer D-3
Pioneer D-3
The rear speakers will just have to try and keep up with the 8"s. I'd try something like 80-100hz, and reduce the output to the point where you can't directly hear them, but if you keep reducing the output, it starts to sound like some thing's missing...
BTW Adidude - Sounds like you've got the makings of a very nice system!
The Scanspeak 2904/6000 tweeter is a great match for those 4"s...
[quote="rocketgyrl"][quote="1nicescion"]
i don't agree, if you set both of the crossovers at the same point you will get a lot of overlapping. i have my sub crossed at 63hz at a 12db slope and the interiors at 80hz at a 12db slope and it sounds much more natural than if i crossed them both over at 63 or at 80. i do agree with you saying to always use the same slope.
anyway... great job on putting an 8" in the doors. where is the mid and tweeter located? any pics of those?
By setting one at 63, and the other at 80hz, you've created a "notch filter" (similar to an EQ)...nothing wrong with that, as long as it sounds better! It's likely the vehicle needed reduced output in that region..most cars do.
Anyway, the Linkwitz-Riley filter alignment provides -3dB at the xover frequency from BOTH drivers, and when summed = 0dB. Please see:
http://en.wikipedia.org/wiki/Linkwitz-Riley_filter
The ScanSpeak tweeter is similar, but not identical. I'm sure either one would be an excellent choice, but since the 2904/6000 is much smaller, it would be my #1.
The optimal attenuation rate ("slope" or "rolloff") varies depending on many factors, and that's the main issue I have with what you implied. Most people who have been heavily into audio for a long time tend to agree that steeper slopes are better, and 4th order L-R is superior to 2nd order Butterworth in many ways. This really only pertains to active filtering, as there are additional factors when considering rates for passive crossovers. Sometimes it can even be best to use 1st order filters to cross over between drivers, such as when a mid and tweeter are separated by a great distance.
Glad you found what works best for you in your install, but also hope you'll be open-minded about trying steeper rates (and even the same XO point between drivers) in the future, as they might benefit a different system or set of ears.
i would have done an 18db slope but my deck only allows for a 12db slope for the interiors but an 18db slope for the sub but i know it's best to not mix slopes.
and i'm pretty open minded and have tried numerous settings and tweaks. my passion is cars, especially car audio.
I think you meant to say L-R is -6dB at the XO freq and sums flat, not -3dB like the more common Butterworth alignment has. Of course I'm sure you're already aware of the other advantage L-R has over most others, which is the output phase. Once people use 4th order L-R active filtering, it's often difficult to be satisfied with anything less.
I forgot to mention that my system has mismatched crossover frequencies. I'm using 31hz (LP) for the subs, and 40hz (HP) for the midbass - to 3.15KHz, then 3.15KHz+ for the tweeters - all at 12dB/oct (my H/U won't do 18 or 24). I've found that the tC "booms" in that region (30-50hz, like most cars), and in order to get the bass to sound right, removed those frequencies out electrically, and allowed the tC to acoustically fill them back in.
...i know it's best to not mix slopes.
I really like your choice on the 4" drivers, and that you're going the DIY route. As you're familiar with Madisound (save the money and use those tweeters, imo), I'd guess you also know about Parts Express, since they have a good selection of drivers too. If you don't know, another place you might want to check is MCM, as they have quite a few too, and ApexJr is another site that might have some interest to you.
I understand what you did, why you did it, and believe it works very well for your system. However, I am a bit uncertain about your sub's filter, did you really mean "31Hz LP", such that they're only getting the signal below 31Hz? I'd have thought they were getting at least up to 50Hz, considering the dB you're able to reach when competing. I've actually done kind of the opposite for many years, as I really like the advantages that subsonic filters provide, and mine is 6th order with a -3dB point at 27Hz.
Aren't you running a 3-way system, with the subs and the Seas components? If so, I'm really surprised that the mids can handle 40Hz to >3k, while still playing cleanly at loud volume. Getting a greater than 6 octave range while maintaining good performance throughout that entire passband is a lot to expect from any dynamic transducer, but based on your apparent success, that must be one heck of a speaker.
