Alternative Battery to Optima yellow top
Old Mar 22, 2007 | 10:15 PM
rocketgyrl's Avatar
"Block" = engine metal.
The alternator should only have one large gauge wire terminal, positive. The negative IS the metal of the casing and engine block/mounting bracket.
Matt put a new chassis connection under the battery tray, on the frame.
Old Mar 23, 2007 | 12:36 AM
Zebman's Avatar
Well I knew that, but i'd prefer to use where the factory connection is. Is it the connection under the plastic valve cover, above the alternator?
If there's only one terminal on the alt, then why are there two wires coming off of it? I'd get pictures and circle what i'm referring to, but the car is outside in the dark right now.
I didn't have a problem with the lights dimming before I tuned my sub. But I went to a piece of desolate farmland and tuned it, and now it dims really bad on almost any hit.
Old Mar 23, 2007 | 02:48 AM
Neothin's Avatar
here's my big 3 install
Old Mar 23, 2007 | 02:58 AM
Zebman's Avatar
Haha, damn. You've got quite the tangle in those pictures.
That explains the alternator pole. Is the chassis ground the bolt in the top picture near the fuse box? And for the block connection, is that the silver wire near the engine oil cap?
Another question, are battery clamps made specifically for the positve or negative post? I have one that I didn't end up using, and would use it for the negative post connections if I could.
Old Mar 23, 2007 | 03:00 AM
Neothin's Avatar
yes, yes.
i sanded off all the paint ont he chassis + engine block connection points until they were shiny.
the wiring mess on the battery is now fixed, i've got an optima w/ sideposts so it doesnt look as bad.
Old Mar 23, 2007 | 03:03 AM
Zebman's Avatar
Ok, i'm pretty sure I can do this now. That battery clamp will come in handy.
Old Mar 23, 2007 | 03:37 AM
jwaj2002's Avatar
TOCC
ok I know I don't drive a tc, but a few people round here do, and I know I need to upgrade my wires, what guage would yall suggest?
Old Mar 23, 2007 | 03:39 AM
rocketgyrl's Avatar
>4ga.
Old Mar 23, 2007 | 03:43 AM
jwaj2002's Avatar
TOCC
aight, can I get pics of where yall did yours? (actually where the ends are mounted on the block and chassis) so that when I get my 4ga, I can do everyone's
Old Mar 23, 2007 | 03:45 AM
Neothin's Avatar
ummm... look 6 posts above you?
Old Mar 23, 2007 | 03:47 AM
jwaj2002's Avatar
TOCC
Neothin show me where the chassis is grounded at, hard to see with that bunch of grey and blue wires, I see that your alt is easy to get to, I haven't tried finding mine
Old Mar 23, 2007 | 03:50 AM
Neothin's Avatar
first picture bud
Old Mar 23, 2007 | 04:06 AM
jwaj2002's Avatar
TOCC
the bolt above the fuse cover?
Old Mar 23, 2007 | 04:08 AM
Neothin's Avatar
yessir
Old Mar 23, 2007 | 04:12 AM
jwaj2002's Avatar
TOCC
aight, thanks man, now I just gotta buy a spool
Old Mar 23, 2007 | 05:10 PM
Zebman's Avatar
Originally Posted by rocketgyrl
>4ga.
I don't have the money for 0awg right now. Would 4awg work well with a stock alternator and only 1000 watts being used for the stereo?
Plus, that battery terminal is marked as positive. Would it be bad to use it on my negative terminal? I mean, conductive metal is conductive metal, I don't see how it could hurt.
Old Mar 23, 2007 | 08:34 PM
nodsetse's Avatar
^ Ya Zebman, 4 guage will be fine. Doesn't matter what your terminals have written on them, provided you never let positive & negative touch.
Old Mar 23, 2007 | 09:56 PM
Zebman's Avatar
Well, I got it all done. The terminals were different sizes, so the clamp was too big for the negative terminal. I'll be buying a negative specific clamp soon.
As for dimming, it was greatly diminished, but it's still there. I'm hoping that with the alternator turning above idle rpms, the dimming won't be there while i'm driving.
Old Mar 23, 2007 | 10:08 PM
nodsetse's Avatar
^ That's exactly right, once over 2k RPM it should be fine. Autosound competitors sometimes set their idle around that so there's no lack of power while judging is in progress, with the car idling.
EvalEvan66
Jan 27, 2015 02:26 AM
EvalEvan66
Jan 16, 2015 08:34 PM
Kodokan_4
11
Dec 4, 2004 01:34 AM
ma_ttcald
16
Mar 31, 2004 07:39 AM
o4_USDM_bB
Feb 9, 2004 04:06 AM
