amp question
alright so i got a kicker 350.2 amp
its 2 channels(duh lol)
i wanted to know if i could wire two components speakers that are 120 rms to one of the 175 rms channels if i messed with the settings on the amp or is this just not possible
I'm not clear on what you're trying to do and why.
Are you asking if either of the amp's stereo channels can handle the nominal 2-Ohm load that a pair of parallel wired component sets would present? If so, then yes.
If you're asking whether or not a pair of parallel wired 120w rated components could handle 175w, then it depends on the active hi-pass filter frequency & slope, along with source content and duration. With the settings optimized, no problem.
just wire each speaker to separate channels...just set your gains low and dont crank the hell outa it.
That way you don't have to worry about the ohm load changing if you had 2 speakers on one channel, and you wont be in mono off of one channel. You can use Right and Left..
The rule is its better to have a little head room in an amp then to under power speakers. If you are underpowering speakers you are more likely to clip the amp, which is not good for your electrical system, the amp nor the speakers.
but the way your explaining it im still a bit confused. lol
Are you wanting to run 4 sets total, 2 on each channel? Or are you just using a single channel for mono output? This isn't clear, as some presume the latter, based on the replies from others.
bootlgr
Jan 26, 2016 01:22 AM
