Amp and sub question
So I'm getting ready to order the elemental designs sq10 and an amp but I'm not sure if I should get a 2 channel or a 4 channel? I don't have (nor do I plan on) getting aftermarket speakers and I have a pioneer avh4200dvd head unit.
Will the 2 channel be enough? The difference in price from the nine.2 and nine.4 is only $10 but the nine.2 is more watts than the nine.4??
Confused
Confused
Sub amps should be 1 channel (mono). You can bridge a 2 channel to be 1 channel but its retarded. Most full range amps are class ab (inefficient) and only stable to 4 ohms when bridged. The nine.2 is no exception. The signal usually needs to be split with y-cables when bridging (not good). The SQ10 is rated at 250wrms. The nine.2 puts out 400w at 12.5v. Not a good match.
eD gear is another story. But then again some people are fine with mcdonalds.
bootlgr
Jan 26, 2016 01:22 AM
