Auto-Dimming Mirror and SRS Airbag Compatibility Question
Old May 30, 2006 | 08:33 AM
20tCDude05's Avatar
Default Auto-Dimming Mirror and SRS Airbag Compatibility Question
I have looked all over and found few info on the compatibility of the auto-dimming mirror and the SRS airbags. I know you have to wire it with the sunroof. But, is this something that anyone could do? And how long does it take to DIY? I would order the mirror from ScionPartsPeople.com and install it myself and save myself some $$. I did find a Tech Section on this and have any of you tried it? If so, did it make it easier with the Tech? Any info would greatly be appreciated. :D
Old May 30, 2006 | 03:04 PM
speddlysmitt's Avatar
The tech instructions are alot better.
https://www.scionlife.com/forums/viewtopic.php?t=46907
Just use the splice layout on page 2.
The only mod that was easier then this was the door sills. Took me 5 -10 minutes with double checking everything.
Old May 30, 2006 | 07:33 PM
20tCDude05's Avatar
Looks simple. Is there any wire cutting? And how do you connect the new wires with the wires alreadly in the car? Is it just a plug in?
Old May 30, 2006 | 08:16 PM
You use splices, Put plastic piece over wire and clamp down , That cuts the wire and allow you to conect to wire harness of mirror. Real simple.
Old May 30, 2006 | 10:46 PM
20tCDude05's Avatar
Is it possible to mess it up?
Old May 30, 2006 | 11:46 PM
Not if you follow the instructions carefully
Old May 31, 2006 | 12:21 AM
20tCDude05's Avatar
Ok, sounds good. I will get them from ScionPartsPeople then. For $209. Can't wait.
Old Jun 1, 2006 | 03:18 AM
20tCDude05's Avatar
Also, is this something someone with VERY little experience with wires be able do to this or do I have to be a master electrician to do this?
Old Jun 1, 2006 | 04:28 AM
ThePerchik's Avatar
Its pretty easy, i think youw ould have to use the same wire as I did for wiring my radar. Took about 30 min. if you exclude picture time and running up and down for various tools.
https://www.scionlife.com/forums/viewtopic.php?t=119184
Old Jun 1, 2006 | 04:54 AM
20tCDude05's Avatar
Is there any cutting? If so, then I shouldn't do this. IF not, then I will. I just don't want to mess it up and having to pay more. I would like to save $100 to do this.
Old Jun 1, 2006 | 09:22 PM
There is no cutting, all you will need to do is match wires to the diagram by color and crimp with pliers. It is very very easy
Old Jun 1, 2006 | 11:12 PM
20tCDude05's Avatar
You have to crimp wires together? What is that like?
Old Jun 2, 2006 | 12:00 AM
You use pliers to clamp the two ends of the plastic piece together.
Old Jun 2, 2006 | 12:02 AM
20tCDude05's Avatar
You just said there was no cutting.
Old Jun 2, 2006 | 04:33 AM
ThePerchik's Avatar
DUDE, look at the pics, there is nothing to do but squeeze pliers...
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
Scionxa180
Mar 13, 2015 04:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
elzy0000
Jan 16, 2004 04:31 PM
