Avic D3 Installed
Old Mar 21, 2007 | 04:24 PM
wreckage's Avatar
Tested it on "scene" xvid releases with divx work around
What's the divx workaround? I was figuring i'd just have to convert all the xvid over to divx, but that's time consuming and quality losing... The fact that it won't easily play xvid is the reason I haven't bought a D3 yet...
Old Mar 21, 2007 | 07:19 PM
ichibansf's Avatar
There's a program that changes the header of the file to the correct formatting of divx. It is somewhere on avic411.com under d1/d2/d3 general, i believe.
Old Mar 21, 2007 | 07:47 PM
Phanon_TC's Avatar
http://avic411.com/forum/viewtopic.php?t=4950
Old Mar 22, 2007 | 01:45 AM
Scionizer07's Avatar
Put mine in last night and the D3 is freakin Hot!! I have the ipod cable, and I need to get the Sirius tuner, for now, my fm mod sirius will do. I still need to recess it by drilling out the brackets, as I was in a hurry to get it in before it got too dark, but I'm in love with it...
Old Mar 22, 2007 | 03:55 AM
Resu's Avatar
Great choice on product, and it looks amazing especially with the modded interior lights to blue.
Old Mar 22, 2007 | 06:31 AM
triplea87's Avatar
On one of the pictures you said..
Reverse wiring (passenger side kick panel, white harness/pink wire) Why is this suppose to be reversed? can you please explain it a little bit more Thank you and perfect write up i give u big props
Old Mar 22, 2007 | 09:29 AM
The wire is the "reverse" wire, as opposed to the "drive" wire, it tells the unit you are backing up, and it turns on the rear-view camera if installed. I did not hook mine up as I don't have the camera yet and it doesn't really effect the navi.
Old Mar 22, 2007 | 09:54 AM
CarbonXe's Avatar
Looks amazing, I've been looking into this headunit for a while now, can't really go wrong with it! Amazing looks, great features and all for hundreds less than all the others!
Quick question tho, with the location you currently have your's installed, can you still close the cover, or does the volume **** get in the way?
Old Mar 22, 2007 | 10:45 AM
Phanon_TC's Avatar
i modified the brackets (look at the pictures) and it'll have the HU sit further back so the door closes just fine.
whitesmoke from avic411 posted some scion backgrounds to use with the d3
http://avic411.com/forum/viewtopic.p...=asc&start=330
Old Mar 22, 2007 | 11:36 AM
Phanon_TC's Avatar
Originally Posted by this_nikki_tc
Hey I could only get 3 screws to line up on the mountign braket and whats that other black piece you have on the mounting bracket?! Why did you have to drill out hte holes?
Black piece is the metra kit. It fills in the empty sides so it looks much cleaner.
I was only able to line up 2 screw holes in the end with the metra kit. using the stock holes is fine but the door cover won't close as the **** gets in the way. Drilling holes (where the indents are) allows you to close the door cover.
Old Mar 22, 2007 | 04:14 PM
triplea87's Avatar
hey Phantom TC. I know that this unit has VEhicle dynamics. Did you hook up yours and i see that you connected the speed sensor. But what about the rest of the dynamics like RPM Temp? Thank you
Old Mar 22, 2007 | 05:29 PM
Phanon_TC's Avatar
only thing the vehicle dynamics page shows is
voltage, acceleration, side acceleration, angular velocity, slope, direction, and clock.
Old Mar 22, 2007 | 05:44 PM
triplea87's Avatar
i see, where do you have to plug them in the ECU? or that speed sensor is doing everything?
Old Mar 22, 2007 | 05:48 PM
Phanon_TC's Avatar
it does everything for u
Old Mar 24, 2007 | 03:54 PM
GATOR690's Avatar
does ur door close?
Old Mar 24, 2007 | 10:51 PM
rvpps2rocks's Avatar
booo i need to get one of these
Old Mar 25, 2007 | 03:09 AM
triplea87's Avatar
Phanon_TC, one big question for you bro have you hooked up the ILL ( Illumination) Cable? If yes to what and where? Thanks bro your help is much appriciate it.
Old Mar 25, 2007 | 03:57 AM
Phanon_TC's Avatar
http://carstereohelp.net/wireharness_Toyota3.htm
pin 10..
if your using aftermarket wiring harness for toyota vehicles.. it should be the orange color wire for illumination
and yes my door closes with modified brackets
Old Apr 7, 2007 | 05:40 AM
chrischoi's Avatar
steering wheel controls illumination?
Old Apr 7, 2007 | 05:45 AM
xXitsmechrisXx's Avatar
That's freaking sweet man. I want one now LOL
