Battery Problems
Well, its been a while since I've been around here, but I have been having a problem and I cant figure out the answer. So I turn to the best place that I know to get answers for this type of thing.
I started college this fall, and since I started I have been having a problem with my car. I leave my car out in the school parking lot for a week or so at a time. I don't need my car for the most part while I'm at school so I only drive around about once a week or so.
Now this is where my problem is. Every week almost when I come out to my car, the battery is dead. It never fails that the battery will be dead when I go to my car. I had the battery tested at an Autozone after a 3 hour drive back to my home and it tested Good so I don't think its the battery. Also, when I drive the car more than just once a week, once every 2 days or so, I don't have this problem. The car runs fine.
I measured the current from the battery to the rest of the electrical and read .4 Amps. Now I know that the car will pull some amperage as it sits around, the clock and the remote sensors use a little to stay online so I can open the car, but I don't know if its supposed to be that high.
I tried disconnecting most of my extra electrical systems and trying to get the car's electrical down to just the stock electrical setup, but I couldn't get it to drop below .4
As for my extra electrical, I have two amps, a CarPC, a touchscreen for the PC underglow lighting, an AutoPage alarm w/Remote Start; I installed all of these except the alarm which I had a professional shop do (cant get the warranty without it) and I know all of them use an accessory wire so that they should not be able to pull any Amperage unless I turn the car on.
So I was wondering if anyone else had had this problem or something similar, or if someone could go measure the amperage from their battery to the car's electrical system and help me get a baseline of what its supposed to be.
Sorry for the long post, but I figure the more information I give, the easier it might be for someone else to diagnose my problem. Thanks in advance for the help.
Okay, I'm confused, did I state current and amperage backwards or did tmrepp?
Also, tmrepp, when you say to disconnect negative and see if it dumps what do you mean?
Right now I am testing the system by disconnecting the positive wire from the battery and measuring the amperage between the battery terminal and the wiring to the car. Am I measuring it correctly?
Oh, right, okay I understand now.
Do you have any idea of what the current that is being pulled form a stock car is? I think .4 Amps is too much, but I cant find what is causing it to pull that much.
I switched it up.
Disconnect negative as in when you park at school, open the hood and take a 10mm to the battery to take off the negative terminal. See if you can start it after that, if not, you've got battery issues.
As to if you're measuring correctly, yes you are.
ps. Nebster, no need to be an ___ about it. You made your point and corrected me, thank you. Sorry, I'm not trying to sound like a ***** but chill out please.
Originally Posted by nebster
i am very very chill
how long have you been in school? my worry is that the batt has lost its charging power, you may just have to get a new one. or bring the batt to like auto zone and have it tested. whats the voltage you're getting at the positive terminal?
sounds like you have something shorting out, my car sits for a week at a time and i have zero problem so i think something may be shorted out, i have no idea what it could be, my suggestion would be to just start it every 3 or so days
I figured it was something shorting out, but could you or someone else go measure the current of a working battery? So when I'm checking for whatever is causing the open circut I can tell when I've found the problem. If I know that I should be able to fix it.
amperage does not exist, its a very improper term and doesn't exist. current units are amps but amperage does not exist
Regardless, a 0.4A draw is way, way, way too much. You have some peripheral that's not shutting down. The ECU's backup circuit will generally show itself as a load of about 0.01A, generally negligible.
Disconnect your negative battery terminal, and touch the probes of a DVM set to measure amperes, one to the terminal, and one to the post. Then, disconnect stuff one thing at a time until the load disappears (or pull fuses, one at a time).
