Best Subs and Amps for tC?
Old Jun 8, 2006 | 07:51 PM
  #41
richardsayzz's Avatar
friend is giving me his old 10" JL sub w/ box and i was thinkin of pluggin it in with this amp http://cgi.ebay.com/ALPINE-MRP-M450-...QQcmdZViewItem what do u guys think?
this car has crappy bass...my old '05 c230 had an awesome stock system and great bass...everyone would ask me if i had 10s.
i just want a little more thump outta the bass
Old Jun 8, 2006 | 07:59 PM
  #42
SCI_TC_GUY's Avatar
if the JL is a dual 2ohm, you'll be fine... otherwise, you may want to look at other amps..
Old Jun 8, 2006 | 08:40 PM
  #43
i think it is the 3 series JL... its just gonna be one 10
Old Jun 8, 2006 | 08:50 PM
  #44
SCI_TC_GUY's Avatar
but what Ohm load and voice coil configuration is it?? that determines wether or not it will be compatable with the amp
Old Jun 8, 2006 | 10:30 PM
  #45
chubster41's Avatar
I love my RF subs...Ive had the 12" P3's in my car and they rock
Old Jun 9, 2006 | 03:01 AM
  #46
WannaTc's Avatar
Ok, lets say I got 2 ED 13Ov.2 subs, which amp should I get? The ED NINe.2X looks really nice. But if theres a better one for less/equal money let me know.... Also could some one explain the ratings? Like this from the the NINe.2X
RMS Power @ 12.5v : 2 x 200 @4Ohm, 2 x 300 @2Ohm, 1 x 600@4Ohm
Also could someone enlighten me about voice coils?
Old Jun 9, 2006 | 03:38 AM
  #47
Yanki01's Avatar
(1) JL 10w6v2
(1) JL 500/1
Old Jun 9, 2006 | 03:52 AM
  #48
2redgerm6's Avatar
RMS Power @ 12.5v : 2 x 200 @4Ohm, 2 x 300 @2Ohm, 1 x 600@4Ohm.
means
a lot of amp companies measure their stuff at 14.4 volts but a typical charging system puts out around 13.8v. so that 200x2 is a conservative rating compared to the power the amp will be producing. the 200x2 is what the amp will produce with 2 4ohm speakers. 2x300 is with 2 2ohm speakers and 1x600 is those 2 amp channels bridged and with 4ohm speaker typically. there are more ways to wire such as 2 2ohm speakers on each channel of the amp or 2 8ohm on each channel but thats the basics of it.
Old Jun 9, 2006 | 05:53 AM
  #49
retrodrive's Avatar
Image Dynamics for speakers and TRU Technology for amps...loud and as high quality as it comes. It is all in the install though. What the helldo I know though
Old Jun 9, 2006 | 11:24 AM
  #50
SCI_TC_GUY's Avatar
nine.2x won't be enough for 2 13Ov's... you'd need a Nine.1 and the dual 4ohm VC subs...
Voice coils are what allow you to match up certain amps with certain subs... a Single voice coil sub has ONLY ONE impedance... no matter what, you can't change that impedance (measured in ohms)... with a dual voice coil sub, you can have 2 differemt impedances depending on the method you use to wire it... for example:
a dual 2ohm voice coil sub can be wires in parallel to get a 1 ohm final load or it can be wired in series to get a 4 ohm final load... a single 2ohm voice coil sub can only be a 2ohm final load...
If you have 2 single 2ohm VC subs, then the wiring style is exactly the same as if it were 1 dual 2ohm VC sub... you could wire the subs together in parallel to get a 1ohm final load, or wire them together in series to get a 4ohm final load...
Lets take your case as mentioned above:
2 13Ov.2's are rated for 600RMS EACH.
a Nine.1 amp puts out 1200watts x1channel @ 1ohm load.
So to achieve that 1ohm load from the 2 13Ov's, you'll need the dual 4ohm VC type. You'll wire each sub independently in parallel to make each sub a 2ohm final load, then wire both those 2ohm final load subs in parallel together to get a 1ohm final load. As stated before, a 1ohm mono load on the Nine.1 will allow it to push 1200RMS watts.
edit:
BTW- Dual Voice Coil has no advantage over Single Voice Coil other than it has different wiring options(which could be a disadvantage depending on amplifier). Often times people buy DVC because they think it's better than an equal sub with SVC when it really isn't.
Old Jun 9, 2006 | 03:32 PM
  #51
mandos's Avatar
edit:
^^ Yeah...that.
Plus, if you wanted to pick up the pair of 13Ov.2's at the group buy price, give me a call, I'll get you the package discount on the amp
Old Jun 10, 2006 | 07:43 AM
  #52
WannaTc's Avatar
Great, thanks for the explainations (sp??) and info.
Mandos- I saw on there web site I can get like 15% off with 2 subs and an amp, is this the one your refering to?
Old Jun 12, 2006 | 06:42 AM
  #53
My friend is givin me his 1 JL 10" w3 sub w/ box and im thinkin of getting the alpine m450 or m350(opinions?) amp to go with it
would i get some clean bass with this? im tired of the stock speakers having absolutely no bass
Old Jun 12, 2006 | 11:37 AM
  #54
SCI_TC_GUY's Avatar
WannaTc: just call Chris (Mandos) at the number that is on the Elemental Design website. He'll get ya hooked up and figured out.
richardsayzz: The only way to tell if either of those amplifiers will work with that sub is if you physically pull the sub out and look on the back of it to see what impedance (ohm) and voice coil configuration. It should say right on the back, but if not, look at the model number, at the end will be a D2, D3, or D4 for dual 2ohm, dual 3 ohm, or dual 4 ohm.
Old Jun 12, 2006 | 02:10 PM
  #55
mandos's Avatar
Well, the 15% on the amp, yeah...but right now we're selling the 13Ov.2's for $135 a piece + shipping. I can do the package discount on the amp, with the super cheap sub pricing
Old Jun 13, 2006 | 12:21 AM
  #56
it is this sub right here http://mobile.jlaudio.com/products_subs.php?series_id=6
I was thinkin of combining it with the alpine m450 or m650 not sure though.
im leaning towards the 450 because i can get it for a good deal and im not willing to spend too much
or maybe even this amp http://cgi.ebay.com/PHOENIX-GOLD-X40...ayphotohosting
what is your guys opinion ?
thanks!
Old Jun 13, 2006 | 12:52 AM
  #57
Yanki01's Avatar
im fixing to get that sub within the next few weeks! Ill have the rest of my system installed aswell! Im having it hooked up with jl 500/1
Old Jun 13, 2006 | 11:28 AM
  #58
SCI_TC_GUY's Avatar
thanks!
In your post before this one, you said the 10 was a W3... but now you've linked a w6v2... are you POSITIVE it's the W6v2?? NOT knowing exactly what sub model and impedance you have could be detrimental to your setup...
I've heard good things about the Phoenix Gold amp that you've posted...
Old Jun 14, 2006 | 12:44 AM
  #59
yeah at first i thought it was the w3 because thats what i assumed , but then he showed me it and it was the 6 series.
Old Jun 14, 2006 | 11:10 AM
  #60
SCI_TC_GUY's Avatar
ok, what impedance and VC config are they?? D2, D4, or D6?
