The Big Three
Ok,
I'm about to start "The Big Three"
Link: http://www.caraudio.com/forum/showthread.php?t=152355
Question: Does anyone have the lengths of these wires so I can order the right length of wire and not spend too much?
1) Alternator Positive to Battery Positive (optional fuse)
2) Battery Negative to Chassis
3) Chassis to Engine Block
Also, should I fuse the alternator positive to battery positive?
Originally Posted by chicotunner07
so what exactly does this do?
clean install dude^^
will slightly increase your overall voltage and reduce voltage dips on heavy transients in music.
and thank you.
An old co-worker and I decided to this on his truck because I made sense to us. More wire, more paths available for current flow. We use 4awg wire on top of the wire that was already there. Does anybody think that's a bad idea? We were just worried about somehow making a ground loop. It worked just fine and we were able to an improvement with a mulitmeter. I just want to get some opinions.
That's what we figured. Plus we had no 1/0 awg wire. I've got a decent length piece I'm going to use for the ground but it's all I could scavenge up. I wanted use the actual chassis ( the chassis chassis of the car) so I could get a heavy duty ground but I think just beef up the wire at the OEM point is more than sufficient .
Originally Posted by Air2TheThrown
What's the length from the Alternator positive to the Battery positive? I want the positive part to be red and the negatives to be black that's why.
from alt positive to bat positive i'd say grab 4 feet, maybe 5 to be safe. you could always whip out a tape measure and make sure.
then 4 feet should be fine for both of the other ground wires. then grab 6 crimp ends. and to crimp them don't worry bout buying a crimp tool, i just used a hammer and my garage floor.
Originally Posted by STNC
Roger that, what if i wanted to run the cable from the back of the block?
And is this a replacement cable for the positive? or an extra cable? And if it is a replacement cable, which one is it?
what size screw is this?
and if i go ahead and replace the original negative wires with 1/0, that wont hurt anything will it?
i wouldn't replace anything, just run extra wires. the more grounding wires the better.
