Component Speaker front Install questions. Please Help
Old Feb 5, 2006 | 06:39 AM
jwaggz82's Avatar
Default Component Speaker front Install questions. Please Help
I have infinity component speakers and want to install them in my car. How much of the old (current) wiring should be snipped when old speakers are being converted over to a new set? Since the component setup has the crossover I am going to assume a lot of the wires need to be cut. Also, does anybody know which colors go to what?
Is there a current "how-to" for front speaker install?
Old Feb 5, 2006 | 07:31 AM
insanelyx's Avatar
yo. well.... if i remember out of the top of my head.... if u have the factory component system. ur gonna use the 6 1/2" speaker wires as an input. which is comming from ur deck. now. how to remove it. i haven't done so yet. but i might take a look at my car... maybe take some pics and give u a nice how-to set up.
u will use the mid range speaker for input and completly not use the speaker wiring. since the tweeter will get signal from the crossover. and the mid range woofer from the crossover itself. umm heres the wiring from the speakers.. from behind the deck into the speakers....
Radio 12v blue +
Radio Ground brown -
Radio Ignition gray +
Radio Illumination green +
Factory Amp Turn-on N/A
Power Antenna orange +,-
LF Speaker +/- pink - purple +,-
RF Speaker +/- lt. green - blue +,-
LR Speaker +/- brown - yellow +,-
RR Speaker +/- red - white +,-
Old Feb 5, 2006 | 07:35 AM
jwaggz82's Avatar
where do your mount your crossover? do you throw away the plastic keeping the wires intact if you are going to be matting the doors anyway?
Old Feb 6, 2006 | 05:34 AM
insanelyx's Avatar
well.. its up to u where u want the crossover located at. inside the door panel .... somewhere safe from the window/water/wires/etc. ummmmmm... u could double side tabe it to the door or get a back/strap and screw the crossover to it.. and find a suitable place for it.......... options are endless....
Old Feb 6, 2006 | 04:32 PM
PghtC's Avatar
you're better off breaking the stock tweeter off then taping the infinity tweeter to the metal mounting plate where the stock tweeter used to be. That way there is no cutting involved.
Old Feb 7, 2006 | 01:06 AM
jwaggz82's Avatar
do i need to cut the wires or is there a harness that i can just get?
Old Feb 7, 2006 | 01:36 AM
PghtC's Avatar
are you using an external amplifier? If not you will only have to cut the feed from the radio to route it to the input of the crossover. The woofer and the tweeter are fed from there via new speaker wire.
You might want to check with Mandos on here, but I believe that the feed from the HU comes into the tweeter, then goes on to the woofer, so you will want to take that wire to the crossover.
Old Feb 8, 2006 | 03:25 AM
jwaggz82's Avatar
ok cool - im going to PM him. thanks
Old Feb 8, 2006 | 03:43 AM
Yanki01's Avatar
Pics would be nice, or also any1 with a drawing of how it would look.
Im currently running with alpine components but im gonna upgrade to JL components and get a 300/2 amp for those. I want to run NEW wire. How would i get rid of the factory tweet since it has a built in crossover? Is there a way to do that?
Old Feb 8, 2006 | 04:56 AM
jwaggz82's Avatar
I am in the same position. Im thinking about keeping the same crossover and just changing out the tweeter and midrange.
clickclickw00t
Feb 18, 2015 08:57 PM
Erickdimas7
Scion tC 2G ICE & Interior
Jan 16, 2015 03:41 AM
cwong1001
Dec 3, 2014 03:30 AM
rolex87
Oct 17, 2005 01:00 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
