cutting shifter *pix*
Old Jan 28, 2007 | 12:16 AM
s44life's Avatar
Default cutting shifter *pix*
well I got a sweet shift know but that damn shifter is so damn long I'm thinking about cutting it. Since the top of it is threaded, I dunno if I should cut a piece out of middle or jut cut the top and re=thread whats left?
What do you guys think??
Has anyone done this before??
Old Jan 28, 2007 | 12:19 AM
captainlaziness's Avatar
Whaddaya mean just cut a piece out of the middle? How would you re-attach the two pieces?
Old Jan 28, 2007 | 12:21 AM
black_sand_box's Avatar
The Family
How do you plan to reattach it if you cut it out of the middle. I'd cut from the top and rethread.
Old Jan 28, 2007 | 12:31 AM
s44life's Avatar
well I figured you could somehow reconnect it, solder or something, crazy glue and peanut butter as last resort
Old Jan 28, 2007 | 12:33 AM
The Family
Peanut Butter
Old Jan 28, 2007 | 12:34 AM
engifineer's Avatar
That will never hold. You would have to actually weld it and re-chrome it. If you cut it, you need to re-thread it.
Old Jan 28, 2007 | 12:38 AM
Bubble gum and boogers would work better.
Old Jan 28, 2007 | 12:39 AM
s44life's Avatar
well I guess re-thread it is......thanks
Old Jan 28, 2007 | 01:03 AM
hadji's Avatar
You've got to use the smooth peanut butter as the nuts in the chunky style will cause it to fit unevenly. I suggest using Jif as it has better adhesive properties. Then again I could totally be out of my mind, you make the call!
Old Jan 28, 2007 | 02:00 AM
riboflavin's Avatar
try this
https://www.scionlife.com/forums/vie...r=asc&&start=0
it looks clean and shorter.
Old Jan 28, 2007 | 02:07 AM
The Family
Originally Posted by riboflavin
try this
Me Likey. It would be cool if B owners could do that too.
The Family
try this
Old Jan 28, 2007 | 04:08 AM
BrownDogg's Avatar
haha. peanut butter. lol. I have actually seen a guy cut his and just rethread it, turned out nice and clean
Old Jan 28, 2007 | 02:22 PM
s44life's Avatar
now I feel a little better cuz I know someone has done it before and it worked
the shift boot conversions looks sweet and I would do it once I'm done cutting
Old Jan 28, 2007 | 05:00 PM
Scionizer07's Avatar
Shoulda just bought a manual car... Unless you are handicapped and missing your left leg. Then I could see buying the craptomatic. Just an opinion. But yes, you need to cut your shaft down (ouch!) and rethread the top. I would not suggest doing this in the car as there will be a huge mess with all of the blood, er, I mean shavings and such.
Old Jan 29, 2007 | 03:12 AM
The Family
It's an automatic short shifter. LOL
Dr_Isotope's Avatar
Run the new threads before you cut the unwanted height off. Because the shaft is chromed, it's slightly oversize, and your die will (often) run off-center threads if you don't use the existing threading as a guide.
Old Jan 29, 2007 | 03:36 AM
b_wet's Avatar
for my b&m i bought a tap and die set and rethreaded the shifter then i cut it down to the sixe i wanted, about 2in off.
Thats some swell advice right there!! The Doc knows his stuff!
Old Jan 29, 2007 | 03:43 AM
Mightygnu's Avatar
i really don't see the point of shortening the actual shifter on an auto. but have fun. thumbs up!
