ebrake reminder
That would be a simple mod though. A small buzzer under the dash with constant power and the ground to the brake. Problem is it would buzz even when sitting still with the ebrake and ignition on.
No not that i know of. But the squeal, the sound of non rotating tires, the fact that this big stick is sticking up and in the way of the gear shift, and the difficulty accelerating, as well as the red warning in the instrument cluster..... Id say if you cant tell with all those signs that your ebrake is engaged, then your the reason why shampoo bottles comes with directions for use.....
Originally Posted by lbjshaq2345
i drove at least two miles with mine on yesterday. no squel no burn no nothing. like it wasn't even on. still works like new...
But in the future, start looking at your dash. There is a big read light that says "BRAKE" on it that tells you that either the brake system has an issue or that your ebrake is engaged.
Originally Posted by PunkInDrublic
Well you're 16... enough said.
? A manual is where it would happen the most.. you rarely use the ebrake on an auto, and always should when parking a 5spd.
Although, either way, it shouldnt happen in any car
