eclipse CD7000 question
Old May 14, 2007 | 06:55 PM
SidePocketKid's Avatar
Default eclipse CD7000 question
recently picked up a cd7000 HU...and i seem to have a bit of trouble setting it up.
is it supposed to be set on the "3way" or "4sp+sw" setting? my subs seem to barely hit on 4sp+sw..
Old May 14, 2007 | 10:02 PM
rocketgyrl's Avatar
If you have front + rear + sub[s], set it on 4sp+sw. The other setting is for a tweeter, midrange, and sub[s] - otherwise known as "active" crossover. Active is where you have a dedicated pair of amplifier channels for each speaker (tweeter, midrange, sub[s]).
Are you 100% sure you've got the RCAs connected to the subwoofer (non-fading) output? Is the crossover set correctly on your amplifier? What frequency are both the CD7000 and amplifier set to? If possible, you should bypass the amplifier's internal crossover when you're using the source unit's. Where is the gain set on the amplifer[s]?
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
jairolla_89
Apr 2, 2015 09:41 PM
Scionxa180
Mar 13, 2015 04:39 AM
xBassist
9
Jan 21, 2004 07:34 PM
