Eclipse owners: Installing IPC-106 help!
I just got the ipod controller for my eclipse hu. It's a fairly easy install but my question is, which wire can I tap for power? The (least than helpful) manual said that I should run the power to the battery. Can I tap it into the stock radio harness? If so, which one? Thanks for the help!
i believe you can tap the GREY wire at the oem radio harness. that wire is only powered with the key ON. i think it's safe to run the IPC-106 from there, but i'm not sure how much power it actually draws.
i tapped mine at the interior fuse/relay panel
Originally Posted by combatsteve
Does it need constant or switch power?
Originally Posted by Krayzie_Los
i don't think that really matters, but i prefer to have it shut off when the car is off so there's less battery drain, but it's up to the owner
the only big drain would be from leaving the ipod hooked up all the time while the car is off keeping the ipod fully charged. there's no memory in the interface, last played song is kept in the ipod itself.
Thanks for everyone's help...I tapped into the radio harness and everything works. Too bad my hu isn't sirius ready so I cant see the display of the song, etc. But it;s better than using an aux cable and controlling it from the ipod...
TheRedBox
31
Dec 2, 2003 04:53 PM
