Engine start button
I was thinking of getting a start button for me tC. I'm sure this has already been done. How did it turn out? Also, did you bypass the need for the key? Pics would be great!
i haven't seen it done.. if so... it probably wouldn't be clean as you still need the key in the ignition... and don't remember recalling any pics...
better to just insert the key and turn it.. then to put in key and press... extra movement not worth the moeny spent.... not practical for a non-show car.
even remote start is a more showy option... imo.
and yea.... question was asked before like always..
https://www.scionlife.com/forums/viewtopic.php?t=93286
https://www.scionlife.com/forums/viewtopic.php?t=70717
https://www.scionlife.com/forums/viewtopic.php?t=36801
https://www.scionlife.com/forums/viewtopic.php?t=11327
yeah i know. The old post were all last year and left hanging. Thought id refresh it and see if there was any progress. I've heard about the key bypass just want to figure out how it was done.
for bypassing.... you have to give up one of your keys to use the chip inside..... which at that point you're basically rendering the stock engine immobilizer system useless.
you'd need that for remote start though.... for the button... you would still have to insert the key.. and that should be fine for the most part.
Hmmm.....If you were to integrate a start button, you also would have to bypass the immobilizer system and steering wheel lock.
To bypass the immobilizer, I would remove the immobilizer sensor ring around the ignition cylinder and relocate that ring in the dash with your valet key in the center of the ring taped to it. Not sure how to bypass the steering lock though.
Originally Posted by MJVsTC
Or, you could just use your KEY to start the car.
they still have security because you probably still need to insert a key or a fob type device...
the fob type device is what the prius uses for sure.... and then there's that whole upgraded system where you only need to be in within certain proximity.. so you don't even have to take it out of your pocket..
at this point.. if you really want it.... trade in your car for a prius or lexus..
