game system and monitors drain battery?
I read on this site that a game system will drain your battery in your car. If I put in my ps2 slim and headrest monitors in my car will it drain my battery? I have a subs in my car as well and dont want to put these in and have it drain my battery. I know someone has done something like this and I want to know if this is true or not.
if you play the game system with the engine off, then yes...just like leaving your stereo or headlights on.
wire it to acc or ign and only run when the car is on and you will be fine.
yellow top looks like what you need
yellow is both a deep cycle and starting
red is just a more powerful starting with decent reserve time.
If you are going to have your subs/amps on with the power inverter with the car off you need a deep cycle of some kind.
How much current are you going to be pulling?
ps2 slim doesn't pull much of anything.. a simple inverter with your stock battery is fine.
but to really answer your question.. anything that you turn on that uses power... if your car isn't running..
WILL drain your battery.
doesn't matter if you have a itty bitty led bulb in your dome light on... it'll be draining your battery...
lunchbx05
Dec 11, 2014 06:13 PM
carid
Dec 4, 2014 09:35 AM
