gauge swap question
You dont have to change resistors for any color on the gauges, only on the HVAC. Some like their gauges brighter, which is the only time you need to change them. I have never had a customer ask me to make them brighter.. some have even said they would like them dimmer with blue. So that is a matter of preference.
I highly recommend against using pink leds. Pink is not a true led color, it is created by applying a phosphorescent material to the lens (true leds actually emit the correct wavelength, even with a clear lens, due to their chemical makeup) and are known to fade over time. One user on here even tested this and posted up pictures of the color change.
The best way to perform a pink swap is to use white leds and then apply a pink translucent film to the backs of the gauges. This will last much longer and still look good. paperstreetplastics on ebay sells the adhesive backed film in larger quantities. If you have trouble finding what you need, hit me up at engifineer@gmail.com and I can help further.
http://garage1217.com/album1_004.htm
check it...but like engifineer states, i would not recommend doing it.
^^did he state he wouldnt recommend changing the gauge cluster resistor on his posts before? without that two tone film mod the stock resistor is plenty but I would want it brighter on two toned colored setup
Its not recommended because engifneer created the HVAC modification to match the brightness of the gauges. Plus the brighter they are the more distracting they may be. but other than that there are no issues with doing the resister swap. it's all preference.
if there is no problem with resistor swap then ill do it then..
bootlgr
Jan 26, 2016 01:22 AM
mattjk
121
Dec 22, 2004 10:49 AM
