gauges help!
so my friend and i swapped gauges and hvac. his is modded leds to white but when i switched the gauges the odometer had more miles than i actually have. any ideas to return it back to normal?
i guess the mileage is stored in the gauges itself so to speak, so you now have his actual mileage, while e has your lower mileage.
changing that would be very hard since it is usually highly illegal, so you should probably go and get your gauges back. |
yup you are not allowed to change the mileage on the odo...
crap! :doh:
they have to be programmed by toyota (not the dealer) when you buy a new cluster to replace one. So there is no way for you to change it. Just like cars with mechanical odo's, your mileage is stored in the cluster.
What I would do is get your old cluster back, have it swapped and there ya go. Otherwise, you just added all the extra miles on your car that you didn't drive...
