gauges help!
so my friend and i swapped gauges and hvac. his is modded leds to white but when i switched the gauges the odometer had more miles than i actually have. any ideas to return it back to normal?
i guess the mileage is stored in the gauges itself so to speak, so you now have his actual mileage, while e has your lower mileage.
changing that would be very hard since it is usually highly illegal, so you should probably go and get your gauges back.
they have to be programmed by toyota (not the dealer) when you buy a new cluster to replace one. So there is no way for you to change it. Just like cars with mechanical odo's, your mileage is stored in the cluster.
SloTC1
Aug 16, 2018 02:45 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
