Getting XM Antenna Wires Into Car
I have a custom carpc setup, and wanted XM radio. I had to get a new antenna and XM setup for it to work with my configuration.
Now i'm trying to mount the (magnetic) XM antenna where the stock one used to be, but not sure how to get the wire into the car, or trunk more specifically.
Any help would be appreciated.
Brett
Brett
unscrew the am/fm antenna.
with a large flat screw driver (or anything really wide) unscrew the plastic part thats holding on the mount.
on the inside there is a bolt holing the antenna.This bolt is behind the carpet. Very easy to get to.
Then from there I removed the rear seat bottom,all you do is pull up on the seat and it comes out.
Then ran the wire under the seat and into the rear speaker compartment. From there under the door sill and into the glove box. From glove box to the xm tuner in the dash.,
anymore quesrtions ask
i put my xm antenna on the last piece of glass before the hatch there is enough metal there that it will stay in place as far as the wire i ran it under the weather stripping and down the c-pillar and then to the front under the seat and under the carpet
O5_TRD_tC
Feb 18, 2015 09:01 PM
xdejablu3x
Regional - Mid South
Dec 29, 2014 02:15 AM
randode
44
Jun 29, 2004 04:19 PM
